Question about Poulan Pro PB195A46LT 19.5 HP Auto Transmission Lawn Tractor, 46-Inch
Will not go into reverse and it continues forward when removing foot from brake pedal.
On my jcb teletruck the foot brake sticks on untill I rev it quite high Then it shoots off in forwards or reverse .It then works fine untill I apply the footbrake again
sounds like the clevis gear/ pawl is maladjusted, look underneath where the pedal goes through the floor and see if you can find/ adjust the pawl tension
also, could you be accidentally be "setting" the parking brake?
Jan 05, 2015 | Cars & Trucks
Why would a vehicle in reverse move forward
The question is a little vague but I think I know what your referring to. All modern automatic transmissions have torque converters. This is the device that connects the engine to the transmission. All vehicle manufacturers like the trans to be nice and smooth shifting. That's great but it does come with some minor drawbacks. If you are facing slightly down hill and you put your car in reverse but do not step on the gas slightly I can guarantee that you will indeed roll forward. You can eliminate that issue by holding your left foot on the brake while you shift into reverse. Then, as soon as you feel the trans engage, gently depress the gas pedal with your right foot and it will eliminate that forward roll problem.
Sep 25, 2014 | Cars & Trucks
We lost our foot pedal and adaptor for the Lss505. Can we order a replacement
although I've fixed Singer foot pedals I found parts easily. you LSS-505 seems to be much harder. I was surprised to find used ones complete with foot pedal on Ebay starting @ $39.95 Tivax Lil Sew Sew Model LSS505LX featuring 8 Built in Stitch Patterns
Sep 13, 2014 | Tivax LSS-505 Model Michley Lil Sew & Sew...
Hydro gear problems
you need to set the neutral and this isn't something I can teach over the www...
Aug 30, 2014 | Garden
Only forward gears no reverse
hi i there ive had problems with this before its the brake pedal switch underneath the car you need to remove the undertray and replace the brake switch problem should be solved
Mar 28, 2014 | 2004 Smart Forfour 1.5
Have a cub cadet lt 2042. When you take your foot off the forward pedal, unit keeps moving and does not stop. will stop if you hit the reverse pedal. Was told the damper was bad and that has been r
there is a adjustment on the linkage i looks like a triangle shape block with a offset screw on the rear axle near where the rod meets the rear axle move it a little at a time
Jun 08, 2012 | Garden
No brake lights 1985 f-150
The problem more than likely exists with the brake light switch. It is located under the steering column on the brake pedal shaft. There should be a kotter pin or clip that holds it in place. Remove pin or clip and carefully slide the brake rod off the brake pedal shaft. Disconnect wiring and remove completely. To install, just simply reverse the order of removal. On some model Fords, the brake light switch slides over a rod on the brake pedal shaft. If this is the case, you will need to pull forward on the brake pedal shaft (slightly) to remove the switch. Keep me informed if possible. Any other help, feel free to contact me.
Dec 11, 2010 | 1985 Ford F150
Craftsman hydrostatic strains but won't go forward or reverse
There is a brake lever attached to your transaxle, that when activated, pushes dowel pins which serve as brake pistons, against a brake pad which presses against a disk from your transaxle...whew. Much like a disk break on your car.
The pistons, or dowel pins may be sticking, causing you to be "riding your brake". A little disassembly and some good ole WD-40 might loosen up the bind.
Aug 25, 2009 | Garden
Poulan Pro PB195A46LT 19.5 HP Auto Transmission Lawn Tractor, 46-Inch Logo
20 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
