Question about Maytag MGR5750 Gas Kitchen Range
Oven won't heat to desired temp, stops at 100deg and light flashes
Oven reaches 100 deg then stops and a light starts flashing and will not continue to heat up to desired temp.
5 Suggested Answers
  • 22 Answers
SOURCE: inacurate temp
The follow suggestions apply if you are at sea level, or a bit above. If you are in the mountains, you'll have to compensate for altitude issues. You need an accurate thermometer to be spot on. One way is to use an electronic thermometer. Another is to set the oven to 217 degrees, insert a small pan of water into the oven, with a metal tray or pie tin on a lower rack to catch spills and see if it eventually boils. If the water didn't boil, you can adjust the temperature upward in  5 degree steps (see your owner's manual for details). If you've lost your manual, you may be able to go on-line and get a pdf copy of your manual.If the water does boil, you know your oven is accurate within 5 degrees. You can then proceed to re-do the experiment at 212 degrees, if you wish. Then you may use the data to adjust the oven temperature.
Posted on Dec 04, 2007
fridgetech
  • 473 Answers
SOURCE: Fault code f1 came on during a cleaning -
On maytag f1 means there is a problem in the control (erc) and will need to be replaced.
Posted on Dec 26, 2007
tzweeb
  • 318 Answers
SOURCE: After temp is set bottom oven will not heat up to desired temp
you probably have a burnt out or shorted out lower bake element in you r lower oven. it sometimes will actually break apart or look like it sparked thru the black tubular section. it is common and will cause no heat during the bake cycle.
you could try to do a broil and see if it gets hot and that would let you know the control is ok and just needs the lower bake element.
Posted on Jan 28, 2009
freetek
  • 5568 Answers
SOURCE: maytag mgr5765dqd temperature problems
Unfortunately, Maytag is now a division of Whirlpool, just one of many. I don't know your range but if it does not have electronic controls, the adjustment is located within the shaft of the oven temperature setting knob. The slotted screw is fairly deep in the shaft and you will need a small flat-blade screw driver with a slim and long blade. If the oven has control electronics, this adjustment will be located on the main board with the rest of the controls and this is normally located in the upright top section of the range.
Posted on May 01, 2009
Oven (indicator light) clicks on and off
Start the self clean and then move the bar over so it will lock and complete the self clean cycle.
Nov 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
Dacor Oven Thermostate problem
The replacement temp sensor could be defective.
Mar 03, 2017 | Dacor Ovens
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
My iron lights up. when i set the heat choice the green lights on the right flash and it does not heat up
Generally, the lights on the right flash until the desired temperature is reached. When they stop flashing it means the iron has heated to the temp. that you selected. I'm having trouble with mine now, also, so I can't diagnose.
Apr 28, 2010 | Euro-Pro Shark GI490 Iron
New oven thermostat acting nuts
can't find our model with this model # .. i would try cking the wiring / making shure it's correct . normal orp when heating the light is on . not heating light is off . although the thermo is new it may be bad / or possible that it not the correct replacement . hope this helped **** ..
Dec 09, 2009 | General Electric JBS07M Range
Daytona 955i running hot
That is quite normal - these bikes run very hot and will typically reach temp where fan kicks in (103 deg C) while bike is sitting at idle, even if not particularly hot weather. Needs good airflow through the rad to keep the temp down.
Fortunately, when fan comes on it lowers the temp quite quickly.
Jan 07, 2009 | 2006 Triumph Daytona 955i
Oven Temp
After it drops temperature, how do you get it back to the desired degrees? It sounds like the thermostat isn't keeping up.
Nov 15, 2007 | Whirlpool RBS245PDS Electric Single Oven
Maytag MGR5750 Gas Kitchen Range Logo
43 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal De GO PATS
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
