Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
Door on right opens as if the magnet is not strong enough.
When I close the door on the left the right door opens slightly, as if the magnet was not holding. Model AFD2535DES
  • 1,869 Answers
Clean the area where the magnetic door gasket contacts If the gasket appears warped
use your hairdryer on medium to gently heat the magnetic gasket pulling it out toward the door opening to restretch it
Posted on May 20, 2009
Maytag fridge right door won't stay closed
it may be necessary to reset the hinge adjustment to move the door further across the opening giving the magnets a better area to hold on to . there is a slight amount of adjustment in the mounting points of the hinges. You may have to replace the door gaskets as they become hard over time and the magnets cannot work properly in the hard plastic
Jun 21, 2013 | Refrigerators
Freezer door pops open when the Refrigerator door is being closed
My new freezer did the same thing. I contacted the company and they went into the whole leveling thing. What it has to do with is the magnetic seal. The magnets are not strong enough to keep the freezer door from popping open when closing the big fridge door. They share the same duct. I level my doors on the fridge and freezer so they swing shut by themselves after opening. Just the force of the big door when it swung closed cracked open the freezer door about a quarter of an inch and if left unnoticed created a puddle and made the fridge run overtime. I solved the problem by placing strong magnets inside the fold of the magnetic seal at the handle end of the door. This is the flap on the outside the door seal. I used six magnets on the top and six on the bottom. The magnets were from discarded Sonicare tooth brush heads. They are very flat and super strong. You can find something on ebay. My freezer door doesn't budge problem solved. I did call the company and told them I solved the problem and they still insisted it was the leveling. Good luck, Art Knapp
Jan 08, 2011 | Refrigerators
When we close the refrigerator door the freezer door pops open. It seems like a vacum problem?
Dec 24, 2010 | LG Refrigerators
Every time the refrigerator door is closed, the freezer door pops open. How can we better secure the seals?
Dec 13, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have an Estate refrigerator by whirlpool Corporation, model # TT18DKXRQ01 with a 12-07 mfg. date. When you open the refrigerator door, as it closes, the freezer door always opens and closes. Apparently...
I also own a model # TT18DKXRQ01 Estate refrigerator and my freezer door pops open when I close the refrigerator. As you stated, this is caused by the magnet in the freezer gasket not being strong enough to hold. As far as I know, they do not make a stronger freezer gasket but even if they did, it would probably be too costly considering that a standard gasket replacement costs $80.
My solution was to install an adhesive child safety lock on the top of the freezer near the door handle. I purchased the 'Safety 1st Lock Release Fridge Latch' model # HS038 from my local Walmart store for around $5.
You may find this solution to be slightly inconvenient at first but you will get used to it. It sure beats losing food because the freezer door was accidently popped open.
Product information:
http://www.safety1st.com/usa/eng/Products/Home-Safety/Latches-Locks/Details/482-HS038-Lock-Release-Fridge-Latch
Oct 13, 2010 | Estate Refrigerators
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
Left door pops open when right door is closed Also
its a very airtight unit so sometimes the doors popping open when another is closed sort of briskly is normal, or the door has gotten tweaked/bent so its magnetic gasket is not making really good, firm contact with the frame to hold it shut..
the water dripping is (if memory serves me correct) the condensate drain for the unit was prone to sometimes getting clogged, or the pan leaking. you may be able to get a ladder and climb up to the cooling box and see where the water is leaking from and remedy fairly easily.
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | True TM-52 Commercial Refrigerator
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
Nov 10, 2006 | Frigidaire FRU17G4JW Refrigerator
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
229 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
