Question about Bay Networks model 51 - 8 Port Baystack Model 51 10base-t Hub
How to use baystack model 51 - Bay Networks model 51 - 8 Port Baystack Model 51 10base-t Hub
Husqvarna 51 file size
Several bar and chain combinations fit the 51 model saw. If your saw runs an H46 / H80 or H81 style chain you will need a 7/32" (5.5 mm)
If you are running a H21 style chain you will need 3/16" (4.8mm)
May 02, 2014 | Husqvarna Chain Saw Models 51, 55
How to connect 2 unmanaged 24 port switch as one unit
You can connect them using a x-over cable to an unused port. the switch should detect the other switch and trunk it automatically. (don't connect more than 1 or you will get a switching loop and possibly a broadcast storm... which is bad)
Jun 04, 2012 | Nortel Networks BayStack 42024T Switch...
Cf 51 model number doesn't match any of their numbers
toughbook drivers go with cpu such as Pentium 4. Ebay people sells driver disk.
Apr 17, 2012 | Panasonic Toughbook CF-51 Notebook
How to config ip to nortel switch
on the Nortel Passport sw
vlan x
ip address x.x.x.x
ip address netmask x.x.x.x
on the interface
ip address x.x.x.x
on the Baystack
it smilar to the cisco sw
pls try and tell me
Dec 03, 2010 | Nortel 2526T-PWR Ethernet Routing Switch...
I need a manual for Bay Networks router ae1101008 manual
You can find an installation and operating manual for the Baystack AN systems here.
If you need information on how to connect a BayStack AN platform to a Network, you find that information here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 22, 2009 | NorStar BayStack AN Router
Our fire station has a cat5e cable supplying internet access to our internal network from a switch in city hall. It connects a baystack 350 to their switch. If this cable is left plugged in during the...
Very likely an IP problem. The server in City Hall is most likely doing the DHCP assignments for all connected machines, and if there is a LAN server running DHCP also in the firehall, there will be a conflict, which may not manifest itself until the assigned IP leases expire and renew. If this is the case, try a router WITH DHCP DISABLED between the two systems, WAN side toward City Hall. As a quick test, disconnect the cable and run IPCONFIG on a firehouse machine. Note the IP, it should begin with 10, 172 or 192. Reboot the machine, run IPCONFIG again. If the IP comes back, you have DHCP running on something. If you see something like 169.254.???.??? you do not, in that case try hooking up a router configured just as it comes from the box. If anything in the firehouse is wireless, making connection thru a wireless router, the problem may be a simple miswire. WAN side toward City Hall and one of the ports toward your switch, don't use the other three. May need to use the uplink port or a crossover cable between router and switch. (Network admin by day, DJ by night)
Sep 11, 2008 | Computers & Internet
Baystack 425-24T Port 26 disabled
I did what you sugget. Went to CLI and did :
conf t
stacking-mode disable
boot
After the reboot, port 26 is enabled and working. Thanks
Apr 07, 2008 | NorStar BayStack 425-24T (AL2012E41)...
Baystack 425 flashing amber on all ports
Make sure you're using the correct console cable...if it's not wired correctly, hyperterminal will continue to give you a blank stare no matter what you do. A great way to verify your cable is to try it on another switch that's working ok. Your hyperterminal comm settings should be 9600 baud, 8 data bits, one stop bit, no parity, and flow control disabled...assuming no one changed the default console settings on the switches.
If you are still having trouble getting a prompt from the console, you can try the following procedure, although this is only known to work on earlier versions of the Baystack switches...
Shut down the power and wait for about a minute. With hyperterminal connected...turn on the power and type "NetICs" (don't include the quotes) within 15 seconds of turning on the power. This should place you in a privileged mode and allow you to use the menu to reset the switches to factory defaults. Good luck!
Jan 12, 2008 | NorStar BayStack 425-24T (AL2012E41)...
Gbic
Hi from the command line interface you will need to login and then type enable (enter) configure (enter), interface fast ethernet all (enter), no shutdown port (port #). Here is a link to the CLI manual if you need more help: http://www116.nortel.com/docs/bvdoc/baystack/doc_pdf/217152-A_CLI_Guide_for_Ethernet_Switch_325-425_Release_3.5.pdf Let me know how it goes or if you need more help. Regards
Sep 25, 2007 | NorStar BayStack 425-24T (AL2012E41)...
Configuring the switch
The Nortel support site has several support documents including a ?quick setup? guide as well as the full installation manual. I wasn?t quite sure exactly what you were asking for but this should help get you started. If you have any other additional questions let us know.
Jul 16, 2007 | NorStar BayStack 470 Model 24T (AL2012E37)...
Bay Networks model 51 - 8 Port Baystack Model 51 10base-t Hub Logo
82 people viewed this question
Top Bay Networks Computers & Internet Experts
David Payne
David Payne
Are you a Bay Networks Computer and Internet Expert? Answer questions, earn points and help others
