Question about Samsung Washing Machines
Samsung WF395BTPA won't unlock even with door open
Door won't close
IB4G2008
  • 3587 Answers
SOURCE: washer door latch stuck, can't open
ahh..time for "Q" from 007, eh? this interlock feature is a relay controlled issue. Seems that your washer is telling you that it's closed. most likely a relay replacement in control panel area.
Posted on Feb 10, 2008
  • 26 Answers
SOURCE: 2000 Echo with a broken manual door lock. Can't open door to fix
When you try to unlock it.... Do you here it making any sound?
I haven't even been in a Echo, So I can't really know how its setup lol but, i can try and help. :)
When you try to unlock it from the inside of the car do you here any sounds? Does it turn Really easy? Maybe the rod unhooked from the lock,
Have you tried a coat hanger? To try and jigge it open ,
You can remove the seat. :) Might be alittle hard but, it will work so you can take the pannle off, If you take this step BE sure to Disconnected you're Battery.
Posted on Sep 05, 2009
97F350diesel
  • 1326 Answers
SOURCE: driver's door won t unlock on 06 VW Passat if I
Probably the lock actuator or the wiring to the lock up to and even being the master lock switch
Posted on Dec 16, 2009
Testimonial: "97F350diesel was very helpful in drilling down to the probable problem with my car and giving me a ballpark estimate."
caroldon
  • 17129 Answers
SOURCE: I have a front louder
The machine has to reset to bringg tthe lock to release, check the link to the lock settings to make the program complete the cycle and release the lock. Do not force it as you end up damaging.
Posted on Sep 01, 2010
SOURCE: samsung J1045AV door wont open, finished wash
My samsung front loader do wont open , cleaned the pump nothing there , What next ?
Posted on Apr 24, 2011
Won`t unlock all other doors work fine,Don`t even hear a click changed fuse still nothing.
Could be the door solenoid either plug has come off from stretched wires from opening and closing door or the solenoid has packed up altogether.Very common on a lot of cars if fuses are all good.
Apr 21, 2016 | 2008 Pontiac Torrent
2000 toyota echo door
It depends on the actual problem. A body shop may be able to use a tool to go down thru the window sill to unlock the latch. If the latch is damaged, you may have to cut into the door to remove it.
Jul 01, 2013 | Cars & Trucks
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
My isuzu trooper driver door won't unlock
If the door wouldn't close how did you close it to lock it and have to exit out the passage side door? Anyway if the door is open like you said and it's locked you can easily access the locking mechanism without removing the side panel. It's on the side of the door, not the inside and not the outside, but the thin strip visible only when you open the door. There will be two metal pieces that clasp together. You can separate them manually, this will unlock the door.
Jun 13, 2017 | Cars & Trucks
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
I have a 2004 G35 coupe and the gas door won't open even though all doors are unlocked
there is a release threw the trunk check the latch after you open it
Sep 09, 2012 | 2009 Audi A4
Washing Machines Logo
76 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
