Question about Cuisinart DGB-650BC Grind-and-Brew Thermal 10-Cup Automatic Coffeemak
Grinder won't stop
The coffee maker won't stop grinding the coffee. If I turn the coffee maker off and then hit grind off button and turn the coffee maker back on then it will brew the coffee.
SOURCE: Cuisinart grind and brew 10 cup grinder stopped working
My grind and brew is a little different, but when I have this problem, I havve to remove the beans and vaccuum out the bean reseviour. It gets clogged and then it won't grind.
Posted on Apr 04, 2009
co7196
  • 3433 Answers
SOURCE: Grind Off light blinking
There must be a sensor or switch that is stuck. Often the grindings find their way into the nooks and cranys thasurround the mechanism. A bit confused on the grinder off light blinking when the grinder IS off.? But, I'll work with ya on it. Are you saying the light is blinking when it shouldn't be, like when the grinder is on? :-)
Posted on Sep 24, 2009
co7196
  • 3433 Answers
SOURCE: I have a cuisinart with brew and grind coffee
Stuck? how stuck can it be when it is supposed to be removable? Try turn ing it,
SOURCE: Filter Basket pops open while grinding and brewing
Clean all the moving parts with a kitchen grade cleaner and then flush with water and air. The mechanism gets gummed up with coffee and gooey liquid over time.
Posted on Feb 05, 2010
SOURCE: We have a Cuisinart DGB-900
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Posted on Sep 08, 2010
DELONGHI ESAM 5500 WON'T MAKE CAPPUCCINO SAYS GRINDS TOO FINE, BUT WILL GRIND AND MAKE REGULAR COFFEE
have you tried cleaning it as described in your user manual,, can you hit the button for regular grind? there are alternatives, a coffee grinder if failry cheap at 10 dollars US,,
Jun 07, 2016 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
This coffee maker (10 c maker with grinder) beeps it's done every few minutes with water left. we have to brew about 5 times for a full pot, what gives?
Presume this is the Grind & Brew Thermal™ 10-Cup Automatic Coffeemaker, Model # DGB-600BCC
An instruction booklet is available here: http://www.cuisinart.ca/pdf/ibs/en/DGB-600BCC_en.pdf
Review the sections beginning on page 11 of the pdf on Turning Off the Grind Function (if not using the grind feature) and Making Coffee.
Make sure you are turning off the grind function if using preground coffee and that the reservoir lid is securely closed.
Check the Cups Setting button; is sounds like the 1-4 feature may be turned on.
Jan 30, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
When the espresso is grinding, it appears to be grinding continuously and will then stop and the light will come on as if the hopper is empty, even when it is filled with coffee beans.
Turn the big knob in the bean hopper to the largest #. If it works, on the second try turn the knob back down to a #, higher that you had before, but only turn the knob when it is grinding.
Sep 11, 2010 | Saeco Vienna SuperAutomatica Coffee...
Coffee not brewing after grinding
After grinding did you hear the brew group goes up and pump start? If you hear the pump start and stopped, itis blockage in the brewunit metal screen. Just needs cleaning.
If you don't hear the pump starting, the problem is with the faulty micro switch inside the gearbox , that is behind the plate of brewunit.(service center job)
Apr 14, 2010 | Saeco Odea Giro Plus Coffee Maker
Can this be fixed??? my grinder stopped grinding ????
Try to remove all coffee beans first by hand, then s*ck all remaining with a vacum cleaner.
Undjust the grinder to more gross coffee.
Try to work back again the grinder. If it is working then adjust back again to your previus postion but remeber that you can go back again one step at the time so the grinded coffee wil not blocked the grinding plates.
Good luck
Mar 30, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Where is the grind switch on the cuisiart grin & brew
Once you turn the machine on, it should automatically start to grind, unless you press the Grind Off button to make it stop.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-650BC Grind-and-Brew Thermal 10-Cup Automatic Coffeemak Logo
118 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
