Question about Nintendo Wii Console
WII wont turn on after power outage
Power went out. WII wont turn on. Is there a reset or internal breaker I need to trip?
  • Anonymous May 25, 2009
    Had a power glitch. The TV turned itself back on right away, but nothing at all on the Wii. Tried unplugging for 15mins, but no luck. Looking for other reset procedures to try.
  • Anonymous May 26, 2009
    I have the same problem after a power outage and just read somewhere else that there is a reset button on the ac plug. I am going to check it out now and see if that works.
SOURCE: Wii completely stops working after power outage
I just had the same problem as everyone else. I had a brief power loss and our new Wii system's power would no longer work. To fix the problem, I unplugged everything from our Wii and unplugged the power cord from the outlet. I let the system set for 10 minutes and re-plugged the power only. That did the trick. Then I was able to plug everything back up and we are now back to playing.
Supposedly, doing the steps above resets the Wii according to the Nintendo online trouble shooting guide.
Posted on Oct 30, 2008
  • 191 Answers
SOURCE: After Power Outage, wont power up...
did you try the pwr button on the console not just on the remote?
it might have still been fried, some electronics are sensitive- or it was in the middle of an update
Posted on Aug 06, 2009
MrWaffles
  • 5 Answers
SOURCE: Power outage this am. Wii won't even turn on
If the power light is that is suppoed to be red when the wii is off and green when it is on, doesnt even glow red, chances are you left your Wii on for too long and the adapter overheated. Go behind the wii and COMPLETELY unplug the gray box from both the wall AND the wii. Wait for a couple of hours and you should be able to see the red power light when you plug it in. Your best bet would be to unplug it before you go to bed. When you get up in the morning just plug it back in.
Posted on Aug 09, 2009
  • 12 Answers
Usually, after a power outage, a power spike (when the power returns) can disable/blow the fuse in the AC adapter for the Wii.
Try the following steps in this order:
FIRST:
- unplug the Wii's power cord from the wall, and leave it unplugged (from 5 mins. to 5 hours). Then, plug it back into the wall. (Unplugging the power cord from the back of the Wii will not help. You need to unplug the power cord from the wall.)
- This usually helps reset the fuse circuit in the AC adapter, and your Wii should work again.
SECOND:
- open the panel on the AC adapter box in the power cord; since the screws are proprietary, you will need to creatively use existing tools to turn the screws
- check the 3A fuse in that box; if it looks blown, then replace it
THIRD:
- it might be cheaper to replace the AC adapter with another one
FOURTH:
- get the unit repaired
MUST DO:
- buy a SURGE PROTECTOR power bar, and plug all of your expensive items into it (to prevent this from happening again).
Hope that helps!
Posted on Aug 12, 2009
jyackle5
  • 8197 Answers
SOURCE: My wii console wont turn on, its plugged and
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Posted on Dec 12, 2009
Power went out, and my g.e. refrigererator lights are on inside but the ice and water panel is off and fridge has not run sense
Unplug your refrigerator from the wall current. Wait 10 minutes and plug it back in.
The powere outage may have tripped an internal breaker. Usually, unplugging, waiting 10 minutes and plugging the fridge back in....will reset the internal electronics. Good Luck!
Mar 04, 2016 | Refrigerators
Tip
Everything is plugged in but your Wii won't turn on
Okay so you have everything plugged in, but all of a sudden your Wii won't turn on, right? Maybe there was a power outage or your circuit breaker was flipped, or maybe nothing happened, but the fact remains that it won't work and you don't know why.
There is a decent chance that your Wii's power cable needs to be reset.
To reset the power cable you need to:
1) Unplug the power cable from the Wii and the wall.
2) Let it sit and rest for 10-15 minutes.
3) Plug everything back in.
4) Turn on your Wii.
It should work at this point if that is the problem.
It may sound silly but Nintendo built in the reset mechanism due to power cable failures and it often is the resolution to a Wii not turning on.
on Dec 22, 2009 | Nintendo Wii Console
The power went off and wen it came back on the tv wont turn back on
If your power outage wad caused by a surge your tv may have died. Check fusebox for tripped circuit breaker also check tv wall plug fuse in case that has blown. It might be that the tv internal fuse has blown, you should disconnect the tvv from the electricity supply if you intend opening the rear of the set to check this.
If they are all okay the set probably needs the services of a trained technician
Good Luck
Jun 08, 2015 | Televison & Video
Why wont frigidare affinity FAFW4011LWD start after the power went out? No lights come on, nothing.
Good Afternoon Friend,
I understand you are not receiving power to your Frigidaire Affinity washer, model# FAFW4011LWD. I also see that there was a power outage before the symptoms began. I suggest checking the fuses or circuit breaker to make sure that it has not been tripped. If the breaker has not been tripped, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire Washing Machines
Emerson 2.8 Cu. Ft. doesn't automatically turn on after power outage
Check breaker. Was there a surge of electricity when the power went out. This may be a simple fix. Sounds like the breaker is tripped. Test the outlet with a light to see that power is to it.
Feb 04, 2013 | Emerson 2.8 Cu. Ft. Refrigerator - Silver
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
Sep 05, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The power went out for a second yesterday and made everything turn off and turn back on. The wii however turned off and never turned back on. I've tried unplugging and replugging, reset the plug etc and...
Are you sure the plug you are using is still good? Did you have to reset the breaker after the power outage? Try plugging it somewhere else. If it still doesn't work it means something's fried. Try to get your hands on an other Wii power cable and try it to see if it works. If it does then you'll just have to replace the power cord, if it doesn't you'll have to send your console over to Nintendo. Hope this help, please rate and testify =)
Apr 07, 2010 | Nintendo Wii Console
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Nov 22, 2009 | Nintendo Wii Console
The electricity went off this morning...Now the Wii console power won't turn on....
Confirm the wii is plugged in (wall and wii side); if the wii is plugged into a power strip, confirm the power strip is plugged in, and that any on/off or fuse switch on the strip is set to on (may have been tripped during power surge/outage); unplug the wii for 15 minutes (seriously, 15 minutes), then plug it back in and try again.
Aug 09, 2009 | Nintendo Wii Console
Just had a power outage, dishwasher is dead
althought e breakers apear to be on physcally turning them off and then back on especcially after power flashes(the breaker might of partially tripped, and needs to be reset(possible)
Mar 16, 2008 | Frigidaire PLDB998A Built-in Dishwasher
Nintendo Wii Console Logo
607 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
