Question about Philips CCC130AT 13 in. TV/VCR Combo
POWER TURNS ON FOR 30 SECONDS AND THEN TURNS OFF,
I CHECKED POWER SUPPLY READS OK CHECKED SAND BLOCK RESISTOR 3.18 SHOULD READ 3.3K ALSO READ VOLTS 41V ACROSS IT. I NEED TO KNOW WHERE THE IC OR HORIZONTAL OUTPUT IS. I TRIED TO LOCATE SERVICE MANUAL AND WASN'T ABLE TO GET ENOUGH INFO.
  • Gamaliet Figueroa Nov 02, 2007
    I REPLACED 150UFD CAP 200V AT THE POWER SUPPLY AEREA AND ALSO TOUCH-UP COLD SOILDER. IT WORK LIKE IT SHOULD BE.
    Problem Solver:
  • 7 Answers
Are you a qualified technician or a handyman? I ask only because I feel a duty to tell you that it is important that you be honest with yourself as to your ability to fully understand the possible dangers in what you are attempting to fix. Are you using an isolation transformer? If not.........for your own safety do not continue!
A qualified technician would know where to locate the HOR output and your having the service manual may only add to the old adage that "having too little knowledge and attempting too much"  may portend further DANGER to you"
Ask a Techo for a $25 appraisal, that way you'lll learn if it is worth pursuing while remaining SAFE from possible harm.
That's cheap personal protection!
good luck with  one
hattonhall
Posted on Oct 19, 2007
SOURCE:
American lead, how do i convert
How to convert an American lead will depend on where you are. You can buy a universal adapter at most travel stores, but first of all consider the local supply voltage. US power is delivered at 110 volts. Australia, Europe and much of the world have a 220 to 240 volt supply. Connecting a 110 volt machine to a 220 volt supply will create smoke and potentially flames - I've seen a number of disasters. Some machines are made to operate across both supplies. Check the label on the back of the machine, near where the power cable plugs in. If it reads 110 - 220 volt you should be OK. Your local Brother dealer should be able to supply a local market power cable for you. They cost around $30 in Australia.
Mar 03, 2015 | Brother Sewing Machines
How do I properly determine the power supply of a parallel circuit of LED lights? I have 30 LEDS to wire into a large model. I know the individual LEDS each run on a 3 Volt CR2016 watch battery. How
With the explanation of nik you can solve the problem. All you need is a multimeter to measure the consumption of one LED an then you can determine the value of resistors and power of battery. Here is an electric circuit for you to figure the hole connection needed. It is advisable to divide the circuit in blocks in order lo achieve better performance. If one led became short circuit, only the segment where is located will be off. The requirements of power for resistors will be easier too. You can even divide in bore blocks, depending on the power of LEDs.
Sep 18, 2014 | Cars & Trucks
Samsung Plasma won't power on
this is not a capacitor problem. set is only 18 months old - has something to do with x y sustain boards not allowing smps to power on the high voltages.
May 27, 2013 | Samsung Televison & Video
Tv wont turn on
The problem might be on your power supply
1. Try to check the input voltage from your t.v . Use a multimeter to check, the power supplysection is located on where the main plug is connected. There must be a reading 110V or 220V depends on your supply
2. If the supply is o.k check for busted fuse or a open resistor. Replace same rating of fuses and resistors. A open resistor has no reading on a multimeter and also a blown fuse has no reading also.
Hope this may help you......
Aug 22, 2011 | Televison & Video
My bnt 500 does not come on backup, when supply fails output drops to zero.Battery seems ok giving 11.8 wils. These volts dont increase on charging state.Is charging ckt ok. thanks for help. maslam
Check for open Fuses first of all. Test the battery again on load not just with Multimeter. You can use a 10Kw potentiometer resistor or a 80W Car head lamp as the load on battery and see if the voltage still reads 11.8V for the first 30 second. If the Voltage drops rapidly and there are no open fuses, replace the battery. Alternatively contact a local technician for troubleshooting on the Board.
Jun 08, 2010 | InterAct Accessories Powercom Black Knight...
No blue power light and doesnt turn all the way on no starting beep gateway gt5220
I would suspect a bad power supply. Before doing anything make sure power is actually getting to the computer. Check the power cord with a volt meter. You should have around 115 volts. If all is well you need to see if the power supply is putting out the correct voltage. Open the PC up and set the multimeter to DC voltage.
  1. Turn off the PC, but do not unplug it. Open the system unit. Set the multimeter to read DC volts in the next range higher than 12 volts. Locate a power connector similar to the hard drive (or CD-ROM drive connector that is unused) and turn on the PC.
  2. You can also unplug a drive connector and use it. Turn on the PC and insert the BLACK probe into the power connector on one of the BLACK wires. Touch the RED probe to the YELLOW wire on the power connector.
  3. The multimeter reading should be +12 volts. Now touch the RED probe to the RED wire and the reading should be +5 volts. If no readings or different readings occurred, you’ll have to replace the power supply. If the readings were correct, you should check the P8 or P9 connectors at the motherboard. These connectors may also be named P4 and P5. To check these connectors, perform the following:
    • Insert the BLACK probe into P8 at one of the BLACK wires. Insert the RED probe into the P8 connector at the RED wire. The reading on the multimeter should be +5 volts.
    • Check the power going to the motherboard connections by inserting the RED probe into P8 at the YELLOW wire and you should get +12 volts. Leave the BLACK wire touching the BLACK wire at the P8 connector. Check the BLUE wire and the reading should be a -12 volts.
    • Now move the BLACK probe to the BLACK wire on the P9 connector. Test the WHITE wire by inserting the RED probe and the reading should be -5 volts. Check the RED wires on the P9 connector and you should get +5 volts on each red wire. You won’t get exactly 5 or 12 volts, but the readings will be very close, such as 5.02 volts.
    • If the Power Supply is a couple of volts off in either direction, such as when the RED wire should be reading -5 volts but it reads -8 volts, or if there are no readings, replace the power supply. Curtorsey: IT Professionals
Mar 09, 2010 | Gateway GT5220 PC Desktop
Power supply suddenly 'dead'
You check the power supply using multimeter. but before everything make sure the you are getting power from the power outlet.
Here is how you can check the power supply with multimeter
If the wall outlet and the power cord are good, make sure the connection at the motherboard is secure. Then you may have to face the fact that the power supply itself is bad. If you have a multimeter, you can test the power supply output before purchasing a new one. Simply follow these steps:
Mar 22, 2009 | Computers & Internet
Service shop
Is the power supply completely dead ? If so with this model of power supply its very common for the resistor 3318 on power supply to go out. Causing the power supply to completely die. Take out the resistor 3318 its a 470 Ohm 1W resistor. check it if it doesn't read around 430-530 Ohm Its gonna be bad ( most likely ith will read in the mega ohms. Replace with a 470 Ohm 2 W resistor. Also check power supply for cracks
Apr 29, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Dvd player is completely dead.
First thing to check is the power cord with it unpluged. Do you get a resistance there or is it open?? If its no reading at all then the power transformer or fuse or current limiter resistor is open. If you do get a reading then you know your power transformer primary is good. Next measure the AC volts comming from the secondary of the transformer. AC volts? Good! Now Find pin 1 or the end pins on the microprocessor. 5 volts present?? No theres your problem get a schematic and troubleshoot the power supply. Yes 5 volts? Measure the display any volts on it?? Ok im sure by now your gonna say no to one of these and like I said get a schematic and conferm all the voltages are present in the power supply. Most common dead problem in dvd/cd players is the power supply ie transformer,regulator, ic, ect, ect. Good Luck
May 10, 2006 | LG DVD 5183 DVD Player
Philips CCC130AT 13 in. TV/VCR Combo Logo
80 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
