Question about Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual
No kill switch - Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual
Where does the kill switch wires go
Coil too the kill switch , kill switch too the ground good clean metal.. Kill switch is just making the ground conection.. Goodluck..
Aug 11, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
How to replace a kill switch on a husky 288 xp
There should be only 1 screw and one wire connecting the kill switch. The kill switch simply grounds out the ignition. So it is difficult to install improperly. The wire coming from the switch goes directly to the ignition module.
Jun 21, 2014 | Husqvarna 288 Kill Switch Wire Chainsaw...
How do you wire in a kill switch
just eliminate and cut off the wire to the existing kill switch the put any kill switch you want on it and take the main electrical lead to the ignition or what ever it is and put the new kill switch in the middle of the new kill switch you installed I did it before it always works just make sure to eliminate the old kill switch and its connections are no longer needed
Oct 30, 2012 | Coleman Electrical Supplies
Is the kill switch an open switch or is it closed,on the MB3202 McCulloch leaf blower
most units they ground out the coil to kill the engine
Aug 11, 2012 | Garden
No spark
Eigther the kill switch failed or ignition module. Disconnect wire to kill switch if you get spark then switch is bad. Still no spark with kill wire disconnected ignition module quit.
Sep 29, 2010 | Mtd Garden
I replaced ignition coil on a Tecumseh Toro 20018 mower. It would not start without disconnecting green "kill" wire. Now what do I need to do - replace the kill switch? Is the kill switch located on the...
It is a short in the kill switch, or the wire running to the kill switch. check insulation on the wire running to the kill switch and check the routing of the wire to insure that it is not being rubbed by moving parts, or the insulation melted by hot engine parts such as the exhaust system. Finally check that the kill switch itself is functioning properly with a test light or OHM Meter.
Aug 12, 2010 | Toro Garden
I want to put a kill switch on a Honda EM5000x
I do not understand why you would want another kill switch installed. It already has a kill switch for the engine and a circuit breaker that kills the output power. d87e9a3.png
Apr 25, 2010 | Electrical Supplies
92 Cb250 Nighthawk won't start
Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter.
A “very helpful” rating for this answer? Thanks!
Jun 17, 2009 | 1992 Honda CB 250 Nighthawk
My gilera runner has nt got a spark i have changed the magneto flywheel spark plug but still no spark what could it be?
Check the side stand kill switch. It kills the engine so that you don’t start out with the side stand down. If broken or out of adjustment, it would kill the spark. Check for a broken wire at the side stand switch and coupler. Try moving the kill switch by hand. If that doesn’t work then wire a jumper around the switch to bypass it. Check the fuses. How good is the battery? Try a jump start from your car battery. Is the handlebar kill switch on? Check the operation of the ignition switch and all kill switches with a volt ohmmeter.
Jun 11, 2009 | 2005 Gilera Nexus 500
Nordic Track Nordictrack Apex 4100i Treadmill User Part Manual Logo
18 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
