Question about Jenn-Air JCD2389G Side by Side Refrigerator
Switching door on Jenn-Air JTB1986-2688 - Jenn-Air JCD2389G Side by Side Refrigerator
2 Suggested Answers
  • 464 Answers
SOURCE: jenn-air sce30600 - replace door lock switch
Hi Don, the part you need is 71001129 and is #13 in the attached breakdown. Hope this helps you get it apart.
Posted on Nov 08, 2009
Jenn-air micro convection - cooling fan comes on when door is opened, then goes off, intermintent problem
I have seen where one of the door switches becomes intermittent causing the symptoms you are describing, tough to nail down considering there are more than one door switches.
Jun 16, 2012 | Jenn-Air JMV9169B Convection/Microwave...
Can the top and bottom doors be switched? (jenn-Air double oven jjw9430dds)
I have this same problem, top door won't close completely and the light stays on. Help donmash@aol.com
Nov 24, 2010 | Jenn-Air JJW9430DDS Stainless Steel...
Jenn-air sce30600 - replace door lock switch
Nov 08, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Jenn air microwave JMV8208BA/CA turns on everytime the door is shut
faulty door switch something has reverse its function, moisture or a broken wire. get it replaced
Aug 16, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn-Air electric wall oven door opens slightly when in bake mode
you either have a bent door hinge or a broken door spring.
check the hinges by opening the door and see if it opens past 90 degrees. if it leans towards the floor then the hinges are bent.
if not then your door springs are broken off. you can check this by seeing if the door "feels" heavy when opening.
either way the door should close tight against the frame when up and the light should not come on without opening the door.
Jan 22, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
What is an F9 error and how do I get my oven door open
We solved this by holding the light/door switch in, hit the clean button, then press stop/clear for 3 seconds.
Dec 25, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
I need a wiring diagram for my Jenn-air dishwasher
I removed the circuit board and reinstalled it.
Now is works fine. Bad connection, I guess.
Jun 01, 2008 | Dishwashers
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
5 year old Jenn Air double oven
the door switch contacts are stuck closed causing the oven to stay on.if you can access the door switch try to wd-40 on it.if that doesnt help you need a door switch.
Aug 16, 2007 | Jenn-Air JMW9527C Stainless Steel Electric...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
