Question about Peavey XR 8600D Class D Powered Mixer
No power switch does not engage power
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • Peavey Expert
  • 232 Answers
Take to shop, it should be under warranty...
Posted on Sep 20, 2014
Unit powers on, is unresponsive
It sounds like you need to take it in for repair.
May 07, 2015 | Behringer US600 Ultra Shifter/Harmonist...
How can i get a function switch for a TUBE ULTRAGAIN T1953 (the switch that engages the high pass filter)
If it is one of the toggle switches on the front then IF you can get it from Behringer then it would likely already be soldered to the board. If you just want the switch try a site like mouser.com and search for toggle switch and then narrow your search from there. Not extremely easy, so contact any electronics service center and they may be able to help you as the switch is an standard off the shelf part. Good luck!
Jan 02, 2015 | Behringer Music
1202 fx phantom power swith will not stay engaged
The mechanical push on - push off latching mechanism may have broken. Probably the switch will have to be replaced.
Sep 02, 2012 | Behringer Xenyx 1202fx Mixer 12 Input 2...
Hey my Pyle pro heavy metal distortion peddle isn't working. Everythings fine until I switch to distortion, than no sound comes from my amp. Any suggestions?
Check the switch to see if it is functional with an ohm meter. Also check length of plug and make sure it engages the jack securely as there are about 5 different lengths of 1/4 inch jack available. Are the effects powered by battery or through the amp, or on thier own power?
Jan 27, 2012 | Music
After five minutes, the Tonelab ST turn off, and turn on again, after this, the display screen shows "5F" (or something like). After 10 seconds this happens again, and still happen. Can be valve...
What it sounds like is that the thermal overload protection is engaging because there is a component that is overheating. I don't know what the operating voltage is of 12AX7A/ECC83 but I would imagine that would be one of the hottest components in the chassis along with the switching power supply. There is an issue with your pedal however it is tough to say without looking at it. Sorry I couldn't be more help. Good luck!
Jun 12, 2011 | VOX ToneLab ST Modeling Effects Processor
I have the Boss RC-50 Loopstation. It has been great. Perfect operation for about 8 months. Today, when I started to use it, I noticed that I couldn't select "Phrase 1" by tapping the pedal....
Likely the switch contacts for that pedal have failed. You will probably have to get it repaired. Stomping on the pedals is a good way to damage them, but the switches are often marginally designed anyway...
If you can access the switch you could try getting some CRC226 available at Home Depot in the electrical department into the switch, but often the internal parts of switches fail.
Jan 30, 2011 | Boss Rc 50
I removed a couple of diodes D4 and D3. I added a switch that engages either 2 diodes or two led's. When I engaged the switch for the led's one of the led's went on then went out. I pulled the switch out...
Firstly, the diodes may be there as rectifer diodes depending on what part of the circuit the diodes are in.If they are then by taking them out, you will have an ac voltage not a dc voltage on the anode of the diode. This would be suggested by the voltmeter volts drop when connected. The diodes may also be connected as ac signal rectifiers, whereby the current source is very small hence not providng enough current to light up the LED which is why it is lighting then going out. Try leaving the postive of the diode in (not the end with stripe on body of diode) and connect diode to - end of diode and other end of LED to ground.
Feb 27, 2010 | Boss Mt 2 Metal Zone Effects Pedal
My boss digital delay works when engaged but no sound when not
sounds like the true bypass line has been damagd. Should be easy enough to fix. Pop open the unit and do a visual inspection first, if nothing is noticeable then do a continuity check with an ohm meter from input to output with the delay efffect off. If you don't read a short in this situation then your problem lays within the signal path and its switched path.
Jan 17, 2010 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
The distortion on my Boss DF-2 doesn't work. When I hit the switch it just comes on and then off
Sounds like a defective switch or bad solder joints connected to the switch. Boss uses momentary switches which turn on when the switch is pressed and turn back off when pressure is released. This engages a switching system. If the switch is engaging itself again while the button being depressed, it will cause it go off again. And a bad solder joint would do this too if the signal is not being jumped to the switching circuit properly.
Aug 13, 2009 | Boss Music
Peavey XR 8600D Class D Powered Mixer Logo
69 people viewed this question
Top Peavey Music Experts
Ben Armstrong
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
