Question about Magic Chef MCD1611ST Microwave Oven
Can I turn off the beeping? - Magic Chef MCD1611ST Microwave Oven
Can you turn down the beep on a Frigidaire microwave
Good Morning Friend,
I understand that you want to turn down the beep on your Frigidaire microwave, model# PLMV169DC. You are not able to turn down the beep, but you are able to turn it completely off. If you wish to have your microwave oven operate with no audible signals, touch Help, the number 2 and Clear/Off. To cancel and restore the audible signal, touch Help, the number 2 and START. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire PLMV169DC Microwave Oven
GE JES1344SK01 microwave: turn off reminder beeps
I checked my GE micro information and nothing is said about disabling that annoying beep. Guess GE feels it is for your own good, like a noisome nanny.
Jan 02, 2014 | GE JES1344SK Microwave Oven
GE microwave that will not stop beeping
he most likely cause of this problem is a keypad on the control.
You can try the stop/clear keypad to silence the beeping.
You can put the controls into child lock and see if the intermittent beeping stops. The instructions to turn the child lock feature you have it in the owner manual . The child lock disables most keypads.
otherwise replace the control board.
God bless you
Feb 08, 2013 | Microwave Ovens
Turn off beep on Microsoft Oven
A small number of models have a feature that lets you turn off the beep on the microwave.
If so, it will be covered in the owner's manual.
Otherwise, see this video:
utube.png You-Tube video "ITHDE-vFaiw" placeholder
Jan 30, 2010 | Emerson Microwave Ovens
The camera is not turning on. The lens is out when it should be inside when its turned off. It keeps beeping when i try to turn it on but it will not switch on.. constantly beeping.
Sounds like you've got a lens error and the beeps are signaling your lens is stuck. With the camera laying on its back, try tapping the lens ring while pressing the start button. You may just luck out. It's about all you can do without taking your camera apart.
Dec 11, 2009 | Microwave Ovens
How do you turn the beep off?
Finally worked out how to do this today! I don't know what model you've got (I don't know what one I've got - it's built in and we've lost the manual) but try pressing the START button for six seconds. This should change the default from 30 beeps to 3 beeps. Bliss.
Apr 16, 2009 | Neff H5470N0GB Microwave Oven
How to turn beep off with Panasonics nnsd297S
Sell the birds or disconnect the beeper.I don't see anything in service manual to help you, its a safety feature.
Apr 09, 2009 | Panasonic NNSD767S Stainless Steel 1250...
Beeping at night
if it beeps you might as well just unplug it
Dec 08, 2008 | Panasonic NN-C994S Convection/Microwave...
Turn off Beep on old Magic Chef microwave
On some older models, there is a sliding switch on the bottom edge of the control panel that turns it off. I've seen these on older Amanas, but not sure about others.
In newer models, they have some kind of help key which will get to to a menu which will turn it off.
Other models in between usually don't have that feature. In such cases, I as a technician have removed the beeper or taped over it to make it quieter, or even lifted one leg of a resistor attached to the beeper.
Someone less technical or less patient could just push the beeper sideways until it snaps off. No more beeps! *grin* And really, it is much weaker than the circuit board so it's a viable, if inelegant solution.
One other thing is to call Magic Chef with your model number:
http://www.mcappliance.com/contactus/contactus.asp
Nov 14, 2007 | Microwave Ovens
Magic Chef MCD1611ST Microwave Oven Logo
16 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
