Question about Cooler Master Choiix Power Fort 5.5Whr black
Choiix Power Fort 5.5 wont charge
Hello! I've got an Choiix Power Fort 5.5. Today is the first time i tried it. I plugged it in to my computer with an USB - MiniUsb cabel that came with the package. First off I get a red flash then three green flashes and then it stops. I've had it in for like 2-3 hours. When i plugg in my USB-Iphone charger i get nothing. If I remove the cable that should charge the powerfort its black, even if i press the button. When i put it in again it gives me the same, red,green,green,green. And if i press the button i get an green light for 3sec. Please help, Did i get it broken or is there anything I can do? I need it on an 20hour flight tomorrow!
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
I have an Asus EEE PC Seashell series. It was left for a week without charging or being used. It will not power up or seem to take a charge. I've tried removing the battery for a few minutes and...
1. try to powercycle the system by pressing down the power button for 5 seconds.
2. try to take the battery out from the computer and connect the powercable from the computer directly to the outlet.
3. turn on the computer.
4.Check for any LED indicator.
5. if still nothing, possible that mobo is bad.
Hope this will help.
May 30, 2011 | Computers & Internet
Hello, well my acer laptop model AO751h doesnt seem to be charging. I check the battery icon and it says "plugged in, charging" but it doesnt seem to be charging cause im sure the battery icon...
is this an older laptop, if so you might just need to replace the battery. or try a different charger before buying a battery. If you need anymore assistance im here
May 20, 2011 | Acer Aspire One AO751h-1211 (LU.S820Y.108)...
Hi! I try to turn on my Iphone 3gs, but it wont. I put it to charge and the charging symbol came up, then it disappeared. Then I took the charger out, and then it's blinking for more batteri. I...
Press and hold the Home button and the Power button for about 30 seconds until you see the Apple logo, then let go. It should power on. If not, plug in to your computer and perform a Restore from iTunes.
May 17, 2011 | Apple iPhone 3G
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
When i plugg in my camera to the computer it wont chrge it wont even turn on if there is a soultion please contact me asap!!!
Hey Sophia,
Have you checked the battery, as the problem seems to be with battery
First of all checked if the battery is inserted properly
Take it off and re-insert it... make sure the +ve and -ve are set properly
If it still does not work...you got to replace the battery
Thanks
Oct 08, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
My RCA Opal MP3 wont show up on my computer and it wont charge
This is battery problem, since it work with your computer directly, you no the computer power supply charge it directly so all you need do now is to get another battery and make sure you charge the new battery for some time before you power on.
Compliments and best of luck
Dec 25, 2009 | RCA OPAL M4001 MP3 Player
USB device does not work
Purchase a usb power plug to plug your device into the wall if it charges then your computer just needs to re install the device driver
Aug 29, 2009 | Sony NWZ-A816 Digital Media Player
Iphone Battery died now it wont charge or turn on
Hello ! I was in panic attack !!! did everthing and nothing seems to wake up my iphone. I forgot to charge it so battery went full empty, then I plug it on the wall charger, and nothing happend. I let it all nite, and next morning,... surprise !!!!! still the red icon, No battery, the iphone didnt restart!!!! How I fix it?
1-unplug it from the wall charger 2- press middle button and startup button, same time 3-when red battery dissapear, plug the charger. 4_ do this many times. Didnt work for me the first time, but at the end it works !!!!
NOW MY IPHONE IS WORKING GREAT !!!!! GOD BLESS YOU ALL !!!!!!!!
Aug 21, 2009 | Apple iPhone Smartphone
It wont start up, push the power button and screen doesnt come on
Please plug also the power cord to the power source then wait for 10 - 20 minutes to charge the battery of your laptop then after the said time given above please turn on the laptop and see if your laptop is working now. Else if it is not then try to contact computer technician and let that person check the problem of your laptop Most of the problem causes of software and hardware.
Thanks
Aug 04, 2009 | Dell Latitude D505 Notebook
Cooler Master Choiix Power Fort 5.5Whr black Logo
26 people viewed this question
Top Cooler Master Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Cooler Master Office Equipment and Supply Expert? Answer questions, earn points and help others
