Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Popping sound, then screen shrunk and went black
The screen went black. There was a popping sound, two horizontal black bars appeared, and moved in together and then shut down the screen. The screen is completely black now, and the standby light is blinking. This is a tv I purchased used a month ago- it is only 4 years old. thanks!
mistersony
  • 320 Answers
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Posted on Oct 20, 2008
welcomejee
  • 10594 Answers
SOURCE: HELP! KDFE55A20 watching TV and screen goes black and loses sound
Yes, its most probably lamp issue.
Please but original Sony lamp from Sony store and replace it in TV.
Posted on Mar 07, 2009
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
SOURCE: Sony kdl-46xbr4 Black Horizontal Bands When I First Turn on TV
I had the exact same problem with the Sony KDL46XBR4. The problem started 11 months after I purchased the TV (Dec 2007). Luckily I placed the call to Sony just before the 1 year warranty expired and they replaced the entire front panel which is basically the whole TV except for the stand and the plastic frame. Last month the same issue started happening again (5 months since the repair). I called Sony and they say they have a 90 day warranty on the replacement part so I would need to pay out of my own pocket to first have the problem diagnosed (it's the EXACT same problem!) and then pay to have the repair done since the warranty has expired. I asked how much the front panel costs and it's $1,400! I paid $2,100 for the TV when I purchased it. Interestingly, at the time that part was back-ordered.....hmmmm, I wonder why??? Perhaps a recall is warranted here (no pun intended). Needless to say, I have sworn off Sony products due to their lack of support for this issue.
Posted on Jun 28, 2009
  • 197 Answers
SOURCE: Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
Posted on Jul 02, 2009
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Greetings, I get a perfectly good picture for about 20 minutes & then it clicks & turns off. I hit the power again & it will go on for less time and shorter and shorter time on until it stays...
Sounds like a component or 2 overheating and probably in the frame stage of the set. You would need the service manual to fix it and someone who is capable. The manual should be obtainable from sites such as www.mauritron.com The make and model would be needed to obtain it.
Feb 08, 2011 | Televison & Video
Horizontal black bar on screen and no sound
It's probably overheating (fan is broken)
You can get a third party to replace it if you want, but I would actually recommend sending it to Nintendo.
Unlike Sony and MS, Nintendo has awesome repair services. They will do any repair under (1 year) warranty for free and if it's not under warranty then they will still do it for cheap. It cost me something like $96 (in Canada) after shipping.
They are also very quick, usually in a week you'll have your system back.
The best part is, whether your system is under warranty or you pay for the repair, you get a renewed 1 YEAR warranty with Nintendo, this is far better than Sony and MS who only do 90 days!
Sep 04, 2009 | Nintendo Wii Console
Samsung hc-p4752w
look for trouble in the low voltage and or high voltage power supply circuits. the popping sound could be an exploded safety capacitor in the horizontal output to the flyback transformer. the horizontal output transistor maybe damaged. chances are the low voltage regulator is also damaged.
Aug 11, 2009 | Samsung HC-P4752W 47" Rear Projection...
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Display shows a set of black bars
tape guides are out of adjustment, need to have brought in for service.
Jan 29, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Black horizontal lines
Sounds as if you have a bad capacitor in the horizontal deflection or video circuitry. You can spot a bad capacitor in circuit with a ESR meter.Hope this helps.
Jan 16, 2008 | Mitsubishi TS-5545 55" Rear Projection...
Taskbar gone crazy on win xp pro sp2
YOu have either a Display Driver problem or the Display Chips itself. try downloading the latest version of display driver if does not fix the problem you need to get your onboard vga repaired.
good luck.
compexaustralia@yahoo.com.au
Dec 05, 2007 | IBM ThinkPad T41 Notebook
Sound but no picture
Basic repair for skilled TV repairman = solder connections on
vertical output IC.........Can be done in home.....T.
Nov 28, 2007 | Sony KV-35S42 35" TV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
13 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
