Question about Nikon Cameras
Nikon Df trigger won't fire displays r43 - Nikon Cameras
  • Harrie Jan 01, 2014
    Hi R McClung, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Is this displayed in the control panel or on the monitor. Does it really say r43 or F 43?
2 Suggested Answers
  • 1388 Answers
SOURCE: my framing nail gun won't
Time for oring kit # d518005 available at Dewalt service center or at www.toolpartsdirect.com.
May as well order the replacement trigger valve while there. These two items will renew your gun. Good luck
Posted on Sep 16, 2011
What does df on interior display of pioneer split heat pump system mean?
In defrosting mode, The LED displays “dF” or alternative displays between running frequency and “dF” (each displays 0.5s)
This means the outdoor unit is in defrost mode, heat pumps will initiate defrost upon demand. Its a normal operation code
Mar 01, 2017 | Heating & Cooling
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Framing nailer won't fire nails
Usually safety foot is not making full contact to trigger mech. First test trigger valve. Remove nails, remove the trigger to expose the trigger firing pin. Connect air and test fire by pushing in the firing pin with your finger (dry fire onto wood or old coiled rubber hose, use very quick pushing action against trigger pin). If the gun works, replace parts and adjust the safety foot so that the lever below the trigger is pushed all the way up and lever depresses the trigger pin all the way in. Good luck
May 26, 2012 | Air Tools & Compressors
My framing nail gun won't fire when trigger is squeezed air leaks out but won't fire
Sep 16, 2011 | Dewalt Round Head Framing Nailer D51845
Can we use a Cobra Auto 150S Compact auto/manual flash and slave unit on a Nikon 5000 SLR
As a slave, yes, though you won't get any of the features of a Nikon CLS-compatible flash unit. You would be shooting in manual flash mode. Due to its higher trigger voltage, I would NOT put the unit onto the camera itself.
May 23, 2011 | Nikon D5000 Digital Camera with 18-105mm...
D90-Sb600 help
The on-camera flash has to flash if you want it to be in commander mode. That's how it sends commands to slave flashes. Set to "--", that's all it does, the flash will not affect the picture.
If you want to operate remote flashes without any flash from the camera, you'll need to invest in a third-party wireless commander and triggers.
Apr 03, 2010 | Nikon Speedlight SB-600 TTL Flash
Can the Vivitar 283 be used safely on Nikon Digital SLR Cameras?
I assume you're asking about the 283, not the DF-283 which is compatible with digital cameras.
As for the 283, yes, if you put an adapter such as the Wein Safe-Sync between the camera and the flash. Under no circumstances should the flash be mounted directly on the camera.
Nov 29, 2009 | Vivitar 283 Flash
SB-600 display shows, but will not fire or test fire
there's a part in inside that triggers the light .. it might need to be fixed.
Please contact Nikon Tech Support to walk you through resetting the flash.
a. Have you tried that? it's in the Manual
Sep 07, 2009 | Nikon Speedlight SB-600 TTL Flash
Nikon Speedlight SB-600 keeps firing
I believe that there is a safety feature built in that if the voltage in the capacitor gets too large the flash will fire, to prevent damage, could be this that is faulty, if it is a new main circuit board is required.
Aug 31, 2009 | Nikon Speedlight SB-600 TTL Flash
Cameras Logo
41 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
