Question about Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw
Homelite Model UT10901A will not Start
This was not used very much. It did run for a while, but stopped to clear the area. Went to start it again, but it wouldn't. Put in new spark plug, because there was no spark. That did not work. What do I check next?
    Guru:
  • 597 Answers
Check the on/off or kill switch. It grounds out the ignition system so that you have no spark. Probably have a loose wire and it's shorting out to ground and making the ignition system not work.
Posted on Jun 03, 2009
Homelite Model D825sd starts on position 2,run for 5-10 seconds on 2 then 3, then stop. It will start again on 2, then the same thing.... I checked the exaust screen, and it's clear.... Help, pelase
Check fuel lines in tank make sure they are not broken or have hole in it. You will probably have to rebuild the carb. As you know you have fire and it will run with proper fuel.
Aug 13, 2017 | Homelite Garden
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
Homelite chain saw won't start
Not the way u want to but i have had luck heating the engine withheat gun. try hair dryer if u dont have a heat gun. Or pull plug out and clean lightly with emery clothe or ~400 grit paper. clean plug before reinserting
Jun 06, 2012 | Homelite Garden
I need a manual for a model10901a chainsaw
I tried both Homelite UT10901A & Homelite Bandit here: http://www.arboristsite.com/showthread.php?t=72322&highlight=beg+manuals
You can join (free) and post your request. Be prepared to be flamed for owning a "homeowner" saw. Lou
Aug 25, 2009 | Garden
Looking for an online user manual. Do you you
I tried Homelite UT10901A & Homelite Bandit here: http://www.arboristsite.com/showthread.php?t=72322&highlight=beg+manuals
Aug 23, 2009 | Homelite Garden
Homelite Chainsaw UT10901A Owners Manual
Hi
This is the closest I found on the net .
hope it helps .
http://www.partsmadeeasy.com/manuals/6164.pdf
All the best and good luck
Jul 19, 2009 | Homelite Garden
Need Manual
Go to jackssmallengines.com/searchdb2.cfm Click parts look up, click parts look up again, choose homelite under select OEM, click homelite, click chain saws, follow down list to model no. and click on it.
Apr 09, 2009 | Homelite Garden
Loss spark
Hi
You need to replace the coil but first try to change the sparkplug and see what is happening.
best regards savumihai71
Jan 13, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite Consumer Products 9.0 Amp, 14 In. Chainsaw Logo
488 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
