Question about Bachmann Crafts & Hobbies
866 engine problem
Lights work but motor does not
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 38 Answers
What's the problem?
Posted on May 06, 2014
Sparking motor
Hi, it's Allan from Dyson.
This is something that a professionaly engineer needs to inspect and look at. To prevent damage to the motor, please turn it off and do not use it.
Please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK). Our experts will be happy to talk you through some further diagnostic checks when you have your machine easily to hand.
All the best,
Allan
Sep 23, 2015 | Dyson root cyclone multi floor vacuum...
Dc18, new brush bar motor fitted, still not turning. power to all connection. suction works ok..
Hi there, it's Jack at Dyson.
If you've tried to repair your DC18 yourself without success, we would usually recommend contacting us directly for some further advice. If needed, we should be able to arrange for a chargeable repair of your machine by a Dyson engineer.
If you're interested in finding out more about your options, you're welcome to call the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 12, 2015 | Dyson Slim DC18 All Floors HEPA Bagless...
03 Chevy Trailblazer left rear taillight will not work. Brake light, back up light & turn signal all work. Right rear all work. Replaced bulbs, switched sides, still nothing.
There was a recall on this, see your local Chevrolet dealer.... Recall Date: NOV 01, 2004 Model Affected: 2003 Chevrolet Trailblazer Summary: ON CERTAIN SPORT UTILITY VEHICLES, VIBRATION AND HEAT MAY CAUSE THE TAIL LAMP/STOP LAMP BULB TO LOOSEN IN ITS SOCKET. IF THIS OCCURS, THE BULB MAY FLICKER AND EVENTUALLY BECOME INOPERATIVE. Consequences: AN INOPERATIVE BRAKE LAMP WILL NOT CONVEY THE DRIVER'S INTENTION OF STOPPING TO DRIVERS IN FOLLOWING VEHICLES, AND AN INOPERATIVE REAR TURN SIGNAL LAMP WILL NOT CONVEY THE DRIVER'S INTENTION TO TURN TO DRIVERS IN FOLLOWING VEHICLES. BOTH OF THESE FAILURES CAN INCREASE THE RISK OF A CRASH. Remedy: DEALERS WILL INSPECT THE TAIL LAMP/STOP LAMP ASSEMBLIES, AND IF NECESSARY, REPLACE THEM. THE RECALL BEGAN ON NOVEMBER 22, 2004. OWNERS SHOULD CONTACT CHEVROLET AT 1-800-630-2438, OLDSMOBILE AT 1-800-630-6537, BUICK AT 1-866-608-8080, OR GMC AT 1-866-996-9463. Potential Units Affected: 871473 Notes: GENERAL MOTORS CORP. Read more: http://www.motortrend.com/cars/2003/chevrolet/trailblazer/recalls/#ixzz2jWJ1eDyR
Nov 02, 2013 | Cars & Trucks
Power steering and brakes do not work when I returned from vacation
RECALL: 2003-2004 Hummer H2 NHTSA Campaign Number: 04V045000
www.nhtsa.dot.gov
Manufacturer GENERAL MOTORS CORP. Recall Date: 02/04/2004 Potential Number Of Units Affected: 68,875 Description SERVICE BRAKES, HYDRAULIC Summary CERTAIN SPORT UTILITY VEHICLES, PICKUP TRUCKS, AND PASSENGER VANS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 135, ?PASSENGER CAR BRAKE SYSTEMS.? SOME OF THESE VEHICLES WERE PRODUCED WITH AN OUT-OF-SPECIFICATION BRAKE HYDRO-BOOST HOUSING RELIEF VALVE BORE. Consequence CONSEQUENTLY, THE VALVE O-RING SEAL MAY FRACTURE. STEERING EFFORTS MAY BE SLIGHTLY INCREASED WHILE BRAKING OR PARKING. UNDER CERTAIN DRIVING CONDITIONS, A FRACTURED SEAL MAY REQUIRE A SLIGHT INCREASE IN THE APPLIED BRAKE PEDAL EFFORT TO ACHIEVE THE SAME VEHICLE DECELERATION RATE AS PRIOR TO THE SEAT FRACTURE. Remedy DEALERS ARE TO REPLACE THE HYDRO-BOOST RELIEF VALVE. THE RECALL BEGAN ON APRIL 26, 2004. OWNERS SHOULD CONTACT CADILLAC AT 1-866-982-2339; CHEVROLET AT 1-800-630-2438; GMC AT 1-866-996-9463; OR HUMMER AT 1-866-486-6376.
Jan 03, 2011 | 2003 Hummer H2
All hooked up, fan works, but lights do not there is a wire that says light connection . do I switch them?
The light wire needs to be connected to the hot lead out of the ceiling. If you have only one hot lead (usually a black wire) connect both the fan motor wire and the light wire to this lead. If you have a second hot lead (usually Red) you can connect the light wire separately.
For free troubleshooting advice call The Fan Man 952-898-2754 or 1-866-600-FANS(3267) www.fanmanlighting.com
Nov 09, 2010 | Hampton Bay 52 In.Carriage House II in...
Need specs to 110 ss motor hd on 92 heritage clasic . need to torqe heads
S&S 110's are a "special" edition. They were produced in limited quanities in celebration of S&S's 40th anniversary. I believe that head torque is a 3 step process ending at 45 ft pounds. Proper engine assembly techniques should be used in the construction of this motor. S&S also has offers technical support at (866) 244-2673.
Oct 21, 2010 | Harley Davidson FLSTC - FLSTCI Heritage...
Washer will fill with water and drain, but it will not agitate spin or move the drum period. The lid switch seems to be working.
the pump is electric. separate from motor
to operate machine. Perhaps you motor is fried? remove belt from motor if motor works
transmission seized , rebuilt from Dasa Mfg
1-866-327-2634 required.
May 26, 2010 | GE WJRR4170E Top Load Washer
Error #e-1
Error 1 come up when the drive motor is not moving. Unplug unit then remove motor shroud then plug unit back in and you will see a circuit board with multiple lights. On Lower portion of the board you should be able to see a amber LED this is your speed sensor light . To test the speed sensor just manually rotate motor fly wheel ( where Drive Belt is visible) and you should be able to see the amber light flickering that means speed sensor is good. Next thing to do is unplug unit and check the motor they sometime get stuck in their chamber so be gentle pulling them out and blow out the excess carbon material out of motor wear a mask when doing the black dust can be much then re assert motor brushes and it should take care of problem. If they are worn (less than 3/8 in. in length) then call Sports Art @1-866-709-1750 the people their are good to work with and any further question they will be able to answer.
Feb 27, 2010 | Sportsart 6300 Treadmill
SPORTSART 6300 SHOWING E 1
Feb 11, 2010 | Sportsart 6300 Treadmill
Does not turn on
I called the helpline and the sent an engineer out. When he took the motor out he deemed it a manufacturers fault and replaced it Free of Charge! He also serviced the whole thing changing belt, filter etc, new brush, new tools and even sent a new soleplate in the post as he didn't have one on the van! All for free
1-866-my-dyson (866-693-9766), between the hours of:-
  • 7am - 8pm (CST) Monday to Friday
  • 8am - 6pm (CST) on Saturday
  • 9am - 6pm (CST) on Sunday
Most questions or inquiries can be solved over the phone by one of our Helpline staff.
Jan 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Crafts & Hobbies Logo
Top Bachmann Crafts & Hobbies Experts
Andrew Taylor
Andrew Taylor
Steve
Steve
Tom Chichester
Are you a Bachmann Craft and Hobby Expert? Answer questions, earn points and help others
