Panasonic sa pt460 manual
Does the 460 support q-link
5 Suggested Answers
SOURCE: cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
SOURCE: Panasonic SA-PT460 without speakers,where do i get the connectors
We have EXACTLY the same problem and have found out from Panasonic that the connectors are unavailable. We are at present trying female connectors covered with heat shrink tubing. Seems to work but having the right ones would be a lot better.
Posted on May 07, 2010
  • 11800 Answers
SOURCE: MY PANASONIC SA-PT460 DVD HOME
You will need a special remote and a special service code for that. The remote can be rented from here
http://www.multiregionupgrades.com/upgrades/panasonic/scpt460.htm
It will come already programmed for your unit and with instruction for a safe use.
Posted on Mar 01, 2011
  • 5185 Answers
SOURCE: where can I download a manual for a Panasonic home theater system sa-pt460 ?
Panasonic Europe has the manual for the SA-PT460, DVD Home Theater System, here: http://tda.panasonic-europe-service.com/docs/2z4f39eba4z3z26151z656ez706466z21zf78945f60f5ba17eb68f8c7e142d774267f7dabf/tsn2/data/ALL/SCPT460/OI/785852/rqtx0089-3b.pdf .
I hope this helps.
Posted on Feb 14, 2012
What type of USB format can I use to view film on my Panasonic SA-PT460 Home entertainment system
Check your owners manual, it should list all of the supported formats for both pictures and video.
Oct 12, 2014 | Panasonic SA-PT460
My panasonic sa-pt460 surround sound system won't play any new dvds, does not recognise them in the system and says no disc, is this something that can be fixed or just because of the age of the syste
Sounds like it may have a hardware problem, specially if sometimes it plays one disc, and others not (I mean the same disc).
But in any case, check to see if there are any firmware updates from Panasonic, that may fix the not recognising new discs issue.
Usually firmware updates are done by formatting a USB pen with a manufacturer's tool and then booting the unit from that USB.
In some others just leaving the firmware file in the USB, and the unit will pick it up an upgrade.
Sep 21, 2014 | Panasonic Televison & Video
Panasonic SA-PT460 disc tray don't opening
The tray mechanism tracks may be binding or the mechanism may lack sufficient power to move the tray.
Dec 30, 2013 | Audio Players & Recorders
Hi i am trying to link my phone (samsung galaxy ace) through the usb so i can listen to music. Help!!! the dvd player (panasonic sa-pt460) doesnt recognise the phone and wont play anything.
What USB do you have ?
I suggest buying an OLD USB kindle charger of ebay they are only cheap and mine works perfectly runs through anything :) hope it helps
Jul 30, 2013 | Cell Phones
Home theatre (panasonic SA-PT460) drive wont open makes some noise when i press the open/close button as its closing. I unscrewed the device and removed the dvd tray from its case as i pressed the...
I also have a problem with the drawer. It opens when I switch the unit on and when I close it - it opens again!
If I switch off at the mains the drawer remains open - to prevent dust ingress I have resolved to holding the drawer in whilst shutting down the power until I get a solution.
If anyone has a solution I would be grateful.
Sep 08, 2011 | Panasonic SA-PT460
Panasonic SA-PT460 disc tray keeps opening. When system switched on disc tray opens, then closes and then opens and stays open. can't play a disc.
SA-PT460
Original fault tray would not stay closed,opened up 460 case and then removed 2 screws on rear of drive. unplug 2 ribbon cables.
unscrew 1 screw in micro switch pcb rotate and spay cleaner into switch and rock switch several times until the reading across switch is 0 ohms before you start you will find the switch has about 2.5 k of resistance across it witch is too high.
as long as you have about 4ohms it will work.
Aug 14, 2011 | Audio Players & Recorders
I got a panasonic sapt 460, which is almost 15 months old, hardly used, but the drive is not opening now. it is making some sound when you press the open/close button but doesn't eject the tray. Any ideas?
I am having the exact same problem with mine and mine is about 15 months old and I hardly use it either. All of a sudden it's just started with this error.
Oct 25, 2010 | Panasonic SC-PT460 Theater System
PANASONIC SA-PT460 CODE FOR MULTI-REGION PLAY
try pressing stop button on unit + more than 10 button on remote simultanously.should reinitialise the unit
Jul 26, 2009 | Panasonic Televison & Video
CAN'T FIND A CODE FOR MY SA-PT460 PANASONIC HOME CINEMA, CAN I GET YOUR HELP PLEASE
PRESS STOP ON UNIT + THE MORE THAN 10 BUTTON ON REMOTE. UNIT WILL REINITIALISE
Jul 12, 2009 | Panasonic Televison & Video
50 people viewed this question
 Grubhead
Grubhead
