Question about Dishwashers
Soap dispensor will not click shut
My kenmore 363.14589100 dishwasher soap dispensor does click shut. The washer does have a note on it saying that the cycle must be over for it to be closed which I make sure it is. I just bought this house and there is no instruction manuel for the dishwasher...
    Problem Solver:
  • 6 Answers
Your dishwasher, although a Kenmore, was made by GE. Dispensers have been a big issue for them in the past; they actually redesigned them quite a bit 3 to 4 years ago. Is it the kind that slides across to lock in place, or does it fold over like a clamshell? Often there is a little spring that holds the lip in place, and it can easily wear out, allowing dispenser to pop open easily. I would check http://www.searspartsdirect.com for technical information, or possibly go to the http://geappliances.com website to see if they can give more information.
Posted on May 20, 2009
When I turn the washer it goes in the load sensing cycle and starts to spin no water comes in and then starts this clicking.
sounds like soap dispenser motor is stalling and or jammed. if you take the top off machine and look at soap dispensor reservoir there is a little motor there this will have a long arm shaped like an arrow that poins to number imprinted on the soap dispensor. check that if its stalling replace it gtg.
Aug 01, 2010 | LG WM2487H Front Load Washer
NO Clean Dishes
dear sir this may be the problem  Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Caution: Because the dishwasher is connected to both the plumbing system and the electrical system, you must consider both systems when working on this appliance. Before doing any work on the dishwasher, make sure the unit is unplugged or the power to the unit is turned off, and remove the fuse or trip the circuit breaker that controls the circuit at the main entrance panel or at a separate panel. Shut off the water supply to the dishwasher at the shutoff in the basement or crawl space under the kitchen.how-to-repair-a-dishwasher-1.jpg
thanks..................................
Sep 11, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Soap dispensor door won,t open
Checkout this tip that I wrote about that problem...
Dishwasher Repair Problem Detergent Cup does not Open
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Jun 12, 2010 | Dishwashers
Kenmore dish washer leaks thru the door, need replacement seal.
I dont know what models but several models leaked thru the soap dispensor in the door.They were recalled. Check the manufacture for your model.
Jan 26, 2009 | Dishwashers
Our dish soap is not dispensing from the flip container.
sounds like you have a water circulaton issue, make sure your getting enough water in machine, and nothing is blocking the dispensor eform getting hit with the waster stream
Jan 11, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
Rinse aid leaks into the dishwasher when the door is closed
sounds like acrack in ht eseal of hte dispensor itself, replacing the dispensor is the remedy
Nov 13, 2008 | Kenmore 24 in. 15652 Built-in Dishwasher
GE Profile Built-in Dishwasher PDW9700L
sorry for the delay. on the modificaton to the dispensor, that , im not aware of anyway. more than likely either something is blocking it from getting full spray of water of simply not enough water in the unit to full expell the detergent
Nov 11, 2008 | Dishwashers
Liduide soap
Hi mansim,
I'm Harvey the Master Plumber.
Your question is: how to use liquid dish soap in the kenmore dishwasher?and which place in dishwasher?
I think it prudent we are first clear on terminology. Based on your discription of your "dish soap", please be certain it says "dishwasher soap". If it doesn't say "dishwasher" on it then it's not meant for your dishwasher.
For a standard american dishwasher the soap goes into a small cmpartment in the door. Just open door fully and you will see the rectangular box on the left. Soap in, then close box. The dishwasher will open it on the second cycle.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Kenmore 15522 Built-in Dishwasher
Kenmore ultra 2 dishwasher
hi thanks for the question leave the little door open when using the soap tabs thanks the appliance doc
Aug 24, 2008 | Kenmore 22422 Top Load Washer
Dishwashers Logo
Top Dishwashers Experts
