Question about Thule 2001 GMC Yukon - SLT, with factory roof rails - Base Rack System
I have a anti freeze leak in the back of my engine and it dont look like its coming from the rear freeze plug. Now what?
Could it be a head gasket leak just below the freeze plug and not a freeze plug? Since I do not see any leak from the rear freeze plug.
Mazda 6 leaking anti freeze steam coming out of right side of engine
can be a few problems --blown head gasket --cracked head-cracked block--popped freeze-out plug--hose line ruptured --water pump --when engine cools down use a flashlight and look on engine as to where the leak/damage is if its in the upper area of engine could be a fixable problem if its the engine block thats a replacement motor
Aug 19, 2016 | Mazda Cars & Trucks
What is leaking anti-freeze from rear left side of engine
frost plug, head gasket ,intake gasket, hose Investigation needed
Jul 23, 2014 | Mercury Grand Marquis Cars & Trucks
99 ford f250 6.8 litre engine i have anti freeze in my two front spark plug ports on the passenger side
could be intake, could be head gasket. take the radiator cap off and fill it to the brim with water, then start the engine and look for bubbles in the water. you might have to top it off while it's running to get a good reading. if any of the plugs you took out were much cleaner than the rest, or had a white crust deposit on them, the head gasket is probably the culprit.
Feb 27, 2013 | Cars & Trucks
Leaking small amounts of anti-freeze, I have to top it off every 2 weeks, maybe 4 oz. I had new tires installed this week and asked the mechanic to look for leaks. He found no issues with any hoses or the...
Most likely a frost plug, you may need a mirror to see it.
The head is not likely to just leak from the back, check for steam from the exhaust when hot.
Jul 27, 2011 | 1998 Volvo S90
I have a 1999 plymouth voyager 3.3 liter van that is leaking antifreeze. I assumed it was probably in one of the hoses. When I got underneath to investigate it seems to be leaking from the rear of the...
I am assuming by anti freeze you mean the radiator coolant.
If it is leaking from the rear of the engine then it is very likey a few of the welch plugs are leaking due to rust.
You need to replace them. Hopefully it is not the engine head gasket which can cost a lot to replace.
May 18, 2011 | Plymouth Voyager Cars & Trucks
I have a kawasaki KX250 motorcycle and there is oil in the radiator.
Check your engine and transmission oil for anti freeze. Also check to make sure your engine breather is not plugged. You probably have a leaking water pump seal , that is allowing oil to get into your anti freeze through the transmission. Normally when this happens the anti freeze goes into the transmission oil.
If there is no anti freeze in the lower engine or transmission , then the oil is leaking from a high pressure oil line going to the head to the cooling chambers filled with anti freeze. This means you probably need to replace your head gasket on the motor. While you have the head off check to make sure that the head has not warped. If it is warped it may have to be machined back to flat or replaced.
Dec 28, 2010 | 2006 kawasaki KX 250
Anti-freeze leaking from the back of the engine
its the lower intake gaskets that go out on them
Jun 05, 2010 | 2002 Chevrolet Blazer
Anti-freeze leaking from either the freeze plug or intake gasket. I need possible solutions. Tone Mac
Without knowing what year or engine size is, I/m just guessing??????? But the 3.1L engines are FAMOUS for intake maniflod gaskets leaking. Look where the intake bolts to the heads. A freeze plug is in the block. Freeze plugs dont leak unless you have been running pure water or weak/cheap anti-freeze. They will rust out from behind and its BIG BUCKS to replace them all.
Dec 18, 2009 | Chevrolet Lumina Cars & Trucks
Anti-freeze leak
The freeze plugs on the back of the block could be corroded and leaking.
Oct 16, 2009 | 2004 Jeep Grand Cherokee
Anti freeze leeking
I have seen a couple of these now with headgasket leaks to the outside of the block just as you describe. I solved them both with a stop-leak additive, not something I would normally use, but I really didn't want to pull the heads because the exhaust studs always break on these engines. I would find out for sure where the leak is before proceeding though. If it's a hose or frost plug, you'll have to repair it properly.
May 14, 2009 | 1994 Nissan Quest
Thule 2001 GMC Yukon - SLT, with factory roof rails - Base Rack System Logo
70 people viewed this question
Top Thule Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Thule Wine and Spirit Expert? Answer questions, earn points and help others
