Question about Echo Garden
Echo es 1000
What is spark plug gap setting
slohry
  • 87 Answers
SOURCE: Spark Plug Gap
.030
Posted on Apr 10, 2009
  • 33 Answers
SOURCE: what's the gap setting for the CD ignition
.005 to.008
Posted on Jul 12, 2009
  • 124 Answers
SOURCE: echo es-210 stop running
This is as simple as it gets. If the carb is 10 years old and has not
been rebuilt in the past 2 or 3 years it will need to be rebuilt or
replaced. The average life of the diaphragms is about 2 to 3 years,
If your carb has limiters which will only allow the adjustment
screws to turn about 1/2 turn, you will likely not get any relief from
adjusting the carb. You will have to take the unit to a local dealer
for help. Most likely you will need to replace or rebuild the carb.
Posted on Sep 13, 2009
mowerman1857
  • 389 Answers
SOURCE: ECHO PB-650 Spark plug gap size
20 thousandths
Posted on Sep 16, 2009
Testimonial: "Thanks just what I needed great result thanks again"
taran_2005
  • 10515 Answers
SOURCE: what is the correct oil to gas ratio for an Echo
Fuel/oil mix ratio should be 32to1 or 32 ounces gasoline to 1 ounce oil.
Thanks!!
Posted on Nov 04, 2009
Testimonial: "Very prompt answer."
Spark plug gap
Most 2 cycle products it should be 0.025
Oct 24, 2016 | Echo Garden
Spark plug gap for a Polaris sportmans 500 a 2010 year
0.028
http://www.polarisatvforums.com/forums/atv-repair-maintenance/14769-spark-plug-gap.html
BKR6ES(STOCK#6364) regular, or IRIDIUM BKR6EIX(STOCK#6418).Gap setting is .028.
That plug is used on all 500 HO from 2000-2011 Sportsman Models.
http://www.polarisatvforums.com/forums/atv-repair-maintenance/40754-500ho-ngk-spark-plug-number.html
http://www.ngksparkplugs.ca/results-motorcycles.cfm?model=empty&enginesize=500&make=POLARIS&apptype=ATV
Here is your manual. Spark Plug page 93. Page 123 says
Spark Plug / Gap NGK BKR6E / .035 in. (0.9 mm)
Different plug (E rather than ES) and gap. check the plug that came out.
http://cdn.polarisindustries.com/polaris/common/parts-manuals/9923420r01_lo_res.pdf
Jul 10, 2016 | Polaris 2004 Sportsman 500 H.O
Spark plug gap size for 02 toyota echo
Spark plug gap size for 02 toyota echo?
NGK BKR5EY Spark Plug Gap: .031 inches or .8mm
Feb 08, 2014 | Spark Plugs BR4HS Plug 10/BX #3322
Echo cs-3400 wont start . no spark. what are the primary and secondary coil readings?
if you have no spark
check for faulty plug 1st, then pull kill wire off at kill switch, then check for grounding ht lead ,
then pull kill wire off at armature , if still no spark most likley faulty ignition armature
i suspect the part number you need if its type 1 is 15662639130
replace it and set air gap and reassemble and test
here is web site for parts
http://www.ereplacementparts.com/echo-cs3400-type-chainsaw-parts-c-35043_35970_36021.html
or you could try www.partstree.com , go to echo saws , then find your model
cheers hope it helps
pauly 46
Jan 28, 2011 | Echo 30.1CC Chainsaw With a 14 In.bar and...
What is the spark plug gap setting for small ECHO CS3450 chain saw with new autolite plug?
0.020" should work well. Check the quality of the spark--it should be blue and snappy with the new plug. Hope this helps!
Dec 10, 2010 | Echo Garden
What is the spark plug gap for my 1987 suzuki 700
Spark plug gap is something that people will have different opinions, set them as per the manual. If you are buying new ones, they should be set as per the manufacturers specification and should not need adjustment. Never bang the plug against something to change the gap, adjust with some sort of lever. Plugs tend to fracture when hit hard enough and you might never know until it doesn't work.
Mar 20, 2010 | 1987 Suzuki GS 700 ES
I need coil and spark plug gap settings for echo hc 1500 type E2 hedge trimmer.
0.026 inch, or 6-8 mm is the plug gap.
The ignition coil air gap range is 0.012 - .016"" or .3 - .4 mm. This is the gap between the flywheel and the ignition coil.
An easy way to gap your coil is use a normal business card between the coil and flywheel, tighten the screws and remove the card.
Oct 23, 2009 | Echo Garden
Garden Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
