Question about Seiko Mantel Clock
Battery changed but not ticking - Seiko Mantel Clock
  • Seiko Master
  • 277 Answers
You may need to try to repair or replace the quartz movement, this link will help you out.
Posted on Jan 25, 2017
Why my APC BR500c ups makes continuous ticking noise when i switch on after a short break in use ?
Are you getting any warning lights? Your post seems to state that this unit is not very old? If still under warranty contact APC, they have fantastic customer service.
Jun 19, 2015 | APC Computers & Internet
Chevy Cobalt ticking when brake pedal depressed?
You poor thing ,dont you you realise its one of them american thingys where the brake light is also the indicator ,totally illegal here in europe where it has to be a amber indicator light anyway the fault lies for sure in the fancy stop light switch ,my best advice would be to buy rear europeon rear lights and have them fitted and that monstosity of a stop light switch with all the relevant horrors of the wiring discarded in favour of a simplier system
Nov 23, 2013 | Chevrolet Cobalt Cars & Trucks
Watch stopped after changing time
It may just be a coincidence that the battery is dead at the same time you changed the hours
Sep 19, 2013 | Nixon Watches
My tag professional ticks over every 4
Your battery is running low and should be changed soon.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
Feb 17, 2010 | Watches
Car won't start, new battery, starter ok, just won't kick over Saturn 2004, 80,000 miles, oil change 2 months ago,
If the starter/Battery are ok.Check for spark by pulling off a sparkplug wire,have someone try to start hold wire near sparkplug tip you'll hear the spark jump to the plug tick..tick..tick..sound.Be carefull to hold wire just far enough to hear spark,also this is the secondary circuit from the coil it's high voltage wear a glove.If you smell gas youre geting gas if no spark it is 1 of the following.Bad Coil, or ignition modulator, crack in distributer, cracked wires that cause spark to not reach plugs.Good Luck.
Sep 09, 2009 | Saturn SL2 Cars & Trucks
Changed positive cable terminal, now battery dead, fuse box ticks
hazard lights left on ? check to see waht relay it is that is clicking anr read to see what it is for? hope this helps
Aug 25, 2009 | 1999 Toyota Sienna
Ford tick over problem
The battery could be slightly weak, making the computer go on the fritz, try a fresh battery!!!! The rev counters bounce often with a weak battery.
Leave feedback good or bad.
Jun 02, 2009 | 1997 Ford Escort
Dell C600 No boot, all lights on exept battery charge indicator
u may need to source a main board..and change it..hope it's still under warranty ...
May 22, 2009 | Dell Latitude C600 Notebook
Ignition won't turn just ticks
why the 4 volt setting? what voltage battery do you have?
Apr 22, 2009 | 2004 Honda VT 600 CD Shadow
Tick, Tick, Tick
It could be a dry or worn bearing on a belt pulley, a dry valve lifter, or a leaky gasket. Pray that it is a leket or pulley, as they are eay and relatively cheap to repair.  also check out check to see if it shakes in drive and reverse. If it does have the motor mounts checked out they could be broken.
Sounds like you may have a bad spark plug wire,the ticking noise you hear may be the spark arching to the block or cylinder head. Open the hood at night and look for blue sparks jumping across the wires.
Oct 29, 2008 | 2006 Pontiac G6
Home Logo
1,131 people viewed this question
Top Seiko Home Experts
Jimmy Accardi
Jerry Greenberg
Jerry Greenberg
Are you a Seiko Home Expert? Answer questions, earn points and help others
