Question about Schwinn Fitness Schwinn 810 GPS Tracking and Heart Rate Monitor
Schwinn gps wont charge
Wont charge
  • jeff allen
    jeff allen Jan 03, 2014
    does anyone know if you can replace the battery in a schwinn 810 watch
My gps wont charge anymore where can i repair it
if you have the 3100 or similar and verified its not charging in the system tab, you can get it repaired HERE or just the part (you need the power port)
if you need further help, just post back to me here and ill help you further.
bill
May 15, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
My Schwinn S-180 scooter won't charge
Check your charger with a meter and see if it is putting out the correct voltage for your scooter battery. If it is, you probably need a battery, probably so anyway after 2 years. Good luck!
Mar 16, 2010 | Transport Schwinn Rechargeable Portable ...
Tomtom930 wont stay charged..cahnged the battery
it sounds like your power adapter isn't supplying enough power to the unit. You should be able to try switching out the adapter with another and see if that helps. If the doesn't help, then there may be a problem with the recharging circuit on your GPS. AT which point you should contact TomTom.
Feb 22, 2010 | Tomtom GO 930 GPS Receiver
Wont turn on charged it it still wont turn on ,
Try holding the power button while plugging it in. Also try holding the power button while wiggling a mini screwdriver in the reset hole
Oct 15, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Schwinn S350 Scooter batteries
Schwinn batteries can be found on amazon, click here and take a look: Amazon com Schwinn S350 Scooter batteries. I hope this was helpful. Cheers
Aug 02, 2009 | Mongoose Currie Schwinn Gt Izip Scooters
Schwinn S400 no power
The batteries are dead. The battery in these scooter need to be kept charged or if not in use for a long time charged every 3months. Otherwise, like what to you, they will go dead. The chemicals in the battery have deteriorated to the point where it won't hold a charge. Replacement batteies are probably available at:
http://www.electricscooterparts.com/schwinnscooterparts.html
Jun 17, 2009 | Transport Schwinn Rechargeable Portable ...
My schwinn scooter wont charge, ive just put a new rear wheel on it and now it wont charge, ive tested the charger and its fine???
Probably a wire disconnected. Check the wiring harness for loose connections, disconnected wires, dirty connections pinched wires, broken wires. Also check and add water to the battery if needed. Check the battery connections and fuses.
Apr 22, 2009 | 2004 Factory bike Chrono SM 250
Schwinn s180 wont charge
hi, just plugg it in turn it on. there should be a red and green light on your charger.
Apr 08, 2009 | Transport Schwinn Rechargeable Portable ...
I charged the battery up on schwinn 180 still want go
Its likely that you just need a new battery. Batteries that are used seasonally have a shorter lifespand, especially if they are stored without being fully charged. You can find a replacement at http://www.batteryinternational.com/electric-scooter-batteries-schwinn-s180.html
Mar 08, 2009 | Transport Schwinn Rechargeable Portable ...
Schwinn Fitness Schwinn 810 GPS Tracking and Heart Rate Monitor Logo
Top Schwinn Fitness Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Schwinn Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
