Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
95 chevy 5.7 4x4 has new oil tune up engine pinging when cold worse when hot
  • Chevrolet Master
  • 1,051 Answers
Sounds like a spark knock. I would set the timing on the engine and if it is ok try some higher octane fuel in the engine or mix some low and high octane gas about 50/50 and see if that helps the condition. If not move the engine timing ahead about 5 degrees. You don't want to move it to far or else the engine will be hard to turn over and start.
Posted on Nov 18, 2015
98 chevy truck 350 engine 93K miles when starting sometimes the engine will backfire..could be cold or hot engine..but after it runs for a couple of minutes will run fine..
A backfire usually indicates a timing issue. I recommend a minor tune up, which will include new plugs and wires, as well as checking/setting the distributor timing. An oil change is also recommended after the issue is corrected, as offset timing can cause fuel to remain in cylinder, which then bleeds past the piston rings and ends up in the crankcase with the engine oil.
Apr 23, 2017 | Cars & Trucks
Do i need head gasket
there are about 8 tests to prove this. and lots of signs.
1: fails compression test.
2: water in engine oil.
3: carbon and oil floating top of RAD filler hole. cap off dead cold
4: constant need for adding AF.
5: steam out tail pipe end, hot engine, fully hot.
6:rad leak down tester fails.
7:the rad blue green tester fails. proves exhaust gasses in RAD.
8: air (seemingly) blasting in to side expansion tank, (combustion gasses actual)
9: engine over heat. and pings. and loss of power.
ill stop here, there are more.
Jul 07, 2014 | 2002 Dodge Ram Pickup 1500
Drags when accellarating
what engine? in that 95 accord.
lost engine power.
hot or cold engine.
even on flat ground. at any speed?
does it have full power up hills, wide open throttle?
ever give it a 60,000 mile tune up this decade?
Jan 29, 2014 | 1995 Honda Accord
1995 Chevy Lumina has a hard time starting up in hot and cold weather after vehicle sits over night, or for more than 3 to 4 hours, it take three to four turns of the key in the ignition before car starts,...
You may need a mechanic for this.
The strong gas smell and the hard starting could be connected.
You could have a leaking injector, or faulty pressure regulator. And you could have a fuel leak in the line.
A mechanic would do a visual inspection of the line from the tank to the engine, and check the cylinders for raw fuel when the engine is off.
Dec 20, 2012 | 1995 Chevrolet Lumina
I was given a 95 chevy s10. It is old and I decided to get the fluids changed. They changed the oil and oil filter and checked everything else. Said all others looked fine. When it's cold runs...
First issue is you have to find the rattle. No way to tell off your explanation what the rattle is. It could be the fan clutch (which is bad if it lets loose at 2500 rpms), you could have a huge number of little leaks of oil from anywhere on the motor causing the smoke. Its older either find someone to fix or try and fix the issues as you find them or it will get worse.
Good luck.
Aug 02, 2011 | 1995 Chevrolet G20
2000 chevy pu.When very cold outside, ticking sound is heard on drivers side of engine.Once engine warms up it is not noticable,but engine does miss. 431 v6
If it's cold outside, then the oil is simply too cold. Do an oil change, and be sure to use a low viscosity oil, such as 5W20. You do not want to use a thicker oil when it's cold.
Your engine misfiring could be the symptom of another problem. I would recommend having a tune-up done - spark plugs, wires, distributor and cap, roter button - and this might clear the problem right up.
Dec 31, 2009 | 2000 Chevrolet Silverado 1500
2003 f150 supercrew 2wd 4.6 romeo has 62000 miles.Pinging noticed when thermostat opens after cold start.Pinging occurs with most throttle positions/loads except full throttle (cant hear it) or idle.EGR...
do not use any fuel additives at all. and only use 87 octane fuel nothing higher. 4.6 and 5.4 ford engines do have a pinging sound especially with a load. but it is normal
Aug 19, 2009 | 2003 Ford F150 Regular Cab
Astro Van is running rough
No,the oil ratings 10w30 and so refer to how the oil viscosity reacts to hot and cold.As far as running rough,when was the last time is was tuned up,cap and rotor if applicable,spark plugs and air filter?Is it carburated or EFI?
Apr 13, 2009 | 1995 Chevrolet Astro
Pinging
Check for a "Knock Sensor" rear engine area, behind intake, mounted in block. Replace with new.
Apr 10, 2009 | 1995 Ford F150 Styleside Regular Cab
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
