Question about Sony KV-36XBR250 TV
TV SONY Trinitron XBR KV-36XBR250
I Here de sound ,bat not video
    Top Expert:
  • Sony Master
  • 75,581 Answers
Check whether the filament of CRT glow or not. If not, check all the solder terminals at the CRT base card. If it glows, check all the voltages at the video output card, said above. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Jan 02, 2014
SOURCE: blinking picture
TV Repairman came out today to look at my Sony KV-36XBR250 today with the exact same problem - he was able to adjust the settings through the service menu, but said it was a temporary fix only.
The picture tube is going and the Sony circuitry has a "video mute" that it uses when it senses the tube is not warmed up enough. The degraded state of the tube causes the blinking on and off as the signal from the tube wavers.
He ballpark estimated the tube replacement cost well above the price for replacing the set with a 37" LCD, so it's going to the dump...
Posted on Mar 13, 2008
SOURCE: no sound (sony trinitron kv-2197pf 21" tv)
try to short the spider transistor along ic amplifier. it is in a mute
Posted on Nov 12, 2008
  • 1274 Answers
SOURCE: I have the Sony XBR 40in Trinitron and it won't
sounds like you have some cold solder or bad joints,power section, inspect it ,with the back off, but be carefull.........i had one that did that...bad connection in solder joint...had to resolder,if you have to resolder,make sure it is unpluged.hope this helped....
Posted on Feb 23, 2010
  • 393 Answers
SOURCE: sony 32" xbr trinitron trusurround T V picture is black
Most likely on a trinitron tube if it is dark is the high voltage capacitor has blown. This is the device that feed the 30,000 or so volts to charge the tube, it attaches at the back with a clip and ****** and a single cable coming from it.
You can check easily if it is definately that as you will notice if you power the tv on and off once or twice if you get that static charge feel from the screen, if there is none there then almost certainly that is the problem.
Posted on Mar 10, 2010
  • 4 Answers
SOURCE: Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Posted on Feb 17, 2011
I recently bough a used 40in sony trinitron xbr. i have the DVI to HDMI cable but wether its my laptop or xbox the sound wont come through the tv at all. any suggestions?
Check the audio cable it might not been connected securely.
Could also be missing.
Even with the HDMI you may still needs it ( DVI is for video only).
DVI means Digital Video Interface.
Sep 26, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
MY sony trinitron XBR TV does not stay on.
what's wrong with my Sony trinitron XBR tv's timer
Apr 27, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
Dec 24, 2009 | Sony Televison & Video
I have a Sony XBR KV-32XBR55 bought in 1992. It
Patty - if you still need these pieces, I have them. Email me at globalmktg@comcast.net either way to let me know.
Dec 04, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Blinking picture
Mar 02, 2008 | Sony KV-36XBR250 TV
SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
check your lamp cover and make sure it is not loose. of so take a philips screwdriver an tighten the cover screw.
Oct 01, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-36XBR250 TV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
