Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Grinder won't stop - Cuisinart Grind and Brew 10 Cup Coffee Maker
Grinder in Krups Espresseria EA8000 stops and whirrs.
Hi, i had similar problem on my Krups. Inner star plastic part which remove powdered coffee is maybe damaged. You need to replace or overhaul your grinder or you can replace inner star plastic part by yourself. Coffee grinder spare repair part plastic inner star Krups Mhle...
Feb 11, 2014 | Coffee Makers & Espresso Machines
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
Machine won't turn off after grinding beans. have to unplug it and wait 20 seconds before repluging it to stop.
Just replace the relay which drives the grinder.
Thats all
You are good to go
Thanks
Please rate my work
Sep 10, 2011 | Bunn -o-Matic G2 (2 lb. Commercial Coffee...
Grinder completely unresponsibe.
Hi
If you have tried opening the adjustment to a larger # and it still doesn't work. Well if the motor won't turn, I only hope the machine is less than a year old because the likely problem is the motor is bad. Sorry
Oct 25, 2009 | Rancilio (RAROCKYND) Grinder
Saeco: grinder stops grinding
Hello, This may be the solution for you: having removed the ceramic grinder to clean out the unit, one of the wires on the grinder had become removed (the "center wire") on the connector. The 2 outside wires were sufficient to give me the illusion that the grinder was connected correctly, however it would only run for a half second and then coast to an annoying stop.
Check all 3 wires that connect to the grinder and make sure they are making contact.
Jun 02, 2009 | Saeco Incanto Rondo
Espresso coffee grinder stopped working
many grinders have resetable termic fuse, some of them require manual reset, so you should search for termic fuse attached to body of motor(open the grinder from below) usualy they are round black termofuses with red reset button.
usualy this happenes when we have loud music and we dont hear that grinder is on and he works long time.
Mar 28, 2009 | Isomac Gran Maccinino Espresso Coffee...
Disc flies off when grinder stops
yes the above is correct with the question "are the threads the right size." but it can also be because u are not slowing the grinder down before stopping it. if the grinder stopps to soon the disk will stay moving. so the disk will fly off. i had the same problem with a pnuematic grinder. sometimes it is the operaters fault not the tools.
" an object in motion aloways stays stays in motion till an outside force dissrupts it."
Jan 10, 2009 | Metabo W6-115 606111420 4 1/2" Angle...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
20 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
