Question about Arctic Air 22 cu. ft. Commercial Freezer F22CWF
Parts for door storage
Need replacement parts for door storage
    Champion:
  • 203 Answers
Try a company called e spares on the internet
Posted on Apr 03, 2014
HOW DO I REPACE D00R SEAL
To replace your seal you'll have to remove the screws around the perimeter of the door's inner panel. Once all the screws are off separate the inner panel from the old seal and peel the seal away. It should peel away easily- if not use a Putty Knife to remove it.
Now take your new seal and "soften" it up a little by placing it in hot water for 10 minutes or so. It'll make it easier to place back in the correct position around the door since the seal was probably all twisted up and sharply folded doing shipping/storage.
Now simply lay it back in the same position the old seal was making sure there are no folds, creases or cuts in the seal. It must lay flat or it will leak all over again. Note: there is a sealant that you may want to get that's specially made for these seals to guaranty the seal gaps are filled and the seal stays in place. I use "Kitchen and Tub" Caulk when I don't have any refrigerator caulk available.
Now reassemble the door inner panel, your new seal, and the outer door all together with the screws you previously removed and you're all done.
If you need more info an excellent source is "Appliance Parts Pro". http://www.appliancepartspros.com/parts-for-frigidaire-ffu14k0dw0.html
Click on your Seal (item #1) and see the comments below that other customers asked.
Hope this helps.
Jun 27, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
Tempt setting
Hi - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Oct 19, 2012 | Frigidaire 16.7 cu. ft. / 473 liter...
Frigidaire freezer always running
Hi Edward - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Oct 13, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
I have been given an upright freezer Model # HUMo46EB
try and get a technician near by to help you fix it up
Mar 04, 2010 | Freezers
Bed room door locked
Take a credit card and slide it around the door latch. Slightly pull on the door as your are doing this and it should release itself. Gently push the card and work it into the latch at a slight angle. Let me know if this works.
Feb 18, 2009 | Hussmann Freezer 12 Facing Straight Glass...
Low suction pressure high head pressure
That system has a restriction. Most common at TXV valve or capillary tube. Will need to be replaced by Refrigeration company. In this video I replaced TXV valve and filter drier due to the same issue You have. Its Ice Machine, Low side was at 5 PSI, High at 250PSI : 404A; should be around 55-65 Low; 250 -275 High. Replaced drier and TXV, machine works proper.
May 19, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Bedroom door sticking
Did you install the doors or a contractor? Sounds like the doors are not fitting the opening properly
Oct 20, 2007 | Hussmann Freezer 12 Facing Straight Glass...
Arctic Air 22 cu. ft. Commercial Freezer F22CWF Logo
83 people viewed this question
Top Arctic Air Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you an Arctic Air Freezer Expert? Answer questions, earn points and help others
