Question about Kenwood DV-605 Multi-disc DVD Player
Tray will not open and it say locked - Kenwood DV-605 Multi-disc DVD Player
Tray lock flashes os screen when i push open, the
possible cause is the rubber belt is loosen,try to replace
Feb 18, 2010 | Audio Players & Recorders
Message on screen SV-DV77, tray lock. Can't open anymore
Solution found on the internet:
Just press the on/off button for about 8 - 10 seconds and the tray will open.
Dec 06, 2009 | Pioneer Audio Players & Recorders
Locked dvd tray
Dear friend,
Press and hold stop+play button on the front panel of the dvd player more than 15 sec the player will be resetting
Mar 29, 2009 | Televison & Video
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
DVD Tray is locked
Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Jan 18, 2008 | Sanyo DWM-390 DVD Player
Disc tray locked on JVC XV-N322
there is a small hole in the front of the tray that will accept a straightened paper-clip. gently insert the clip and the tray should release. if the cd/dvd disc is dislodged from being flat in the tray, it may not come out. you might need to open the cover and manipulate the disc to get it back flat in the tray. a good first test is to see if the disc plays. if it does, it is in the tray correctly and should be easily released with the paper clip. the try might work after you release it.
another possible first try would be to gently push inward on the tray after telling it to release. if there is extra tension on the tray it could cause the mechanism to not release. freeing the tension on the tray could be all that you need to get the 'unlock' to release. (kinda like trying to open a door when someone is pushing it very hard against the lock mechanism. it wont be able to move).
good luck
mark
Jan 03, 2008 | Televison & Video
Locked dvd tray.
Press and Hold EJECT Button, While UNLOCK Is Displayed :-)
Nov 12, 2007 | Sanyo DVD-7201 DVD Player
No tray function
You have to press both the "on" button and the "preset" button to lock-unlock the tray
Sep 26, 2007 | Yamaha DVR-S120 DVD Player
My dvd/cd try does not open when i press the eject button say "locked"
That means your trays are on Child Lock (this is a safety feature to prevent any accidental opening or closing of disc trays by small children when listening to your favorite tracks.)
To solve this, simply switch off your radio to Standby and hold the power button...whilst holding the power button, press open on the tray that is locked....the system will display UNLOCKED on the display of your hi-fi.
That should be it. To lock the tray....repeat the same process on the particular tray u want locked.
May 21, 2007 | JVC DX-T9 System
Kenwood DV-605 Multi-disc DVD Player Logo
Top Kenwood Televison & Video Experts
Jaime Hernandez
Jerry Greenberg
Jerry Greenberg
Are you a Kenwood Televison and Video Expert? Answer questions, earn points and help others
