Cpu common problem and solution - Computers & Internet
    Master:
  • 683 Answers
If your cpu has a problem then solution is to replace cpu
what is the question here??????
Posted on Jan 02, 2014
The computer won't start up
does the computer put anything on the screen?
does the computer one beep after self test?
what kind of lights or no power at all
any errors. windows boot up problems
Jul 08, 2015 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Error 17
"Initialize cache before memory autosize"
This is the cache in the CPU.
The most common cause of this error is the CPU has been overheating.
Check the airflow.
Overheating can destroy the CPU.
Mar 19, 2014 | Tyan S5397WAG2NRF Dual Lga-771 Xeon Ddr2...
Error 17
Check the airflow.
Mar 19, 2014 | TYAN S5397WAG2NRF Dual LGA771 XEON DDR2...
Cpu high temperatures
Watch a complete step by step instrucitonal video on how to fix a CPU that is running at high temperatures risking overheating the computer. This is a common problem for people who overclock computers. After the fix in the video was performed the CPU core temperature dropped from 57 degrees celsius to 46 degrees celsius, but that's not all. The 46 degree CPU temp was taken with Sisoftware Sandra Lite after the computer was overclocked from 2.4 GHZ Stock speed to 3.1 GHZ.
http://www.youtube.com/watch?v=-pGOss4xkZM
Jul 31, 2012 | Computers & Internet
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
I have a sony vaio laptop.. after using it for a several minutes, my laptop will shutdown without any warning.. I check the the cpu fan but it works fine, please help me..
You can download a software to monitoring the temperature of CUP, motherboard, graphics and so on, and to see if them are all right. The CPU fan work find doesn't mean the temperature of CUP is common. Maybe you need do a cleaning of the inside of your laptop, or you need to add silica gel between the cooling fin and CPU to get good cooling. If the temperature of other hardware if not common, you can do it as above too..
Feb 16, 2011 | Computers & Internet
I am getting sound in my system
HI User ,
The sound from system can come due to various reasons, The most common reason is the CPU fan which located in the back of the CPU tower and also just above the CPU Processor . Due to Heat Sink between Processor and Fan ,it can create a loud noise when the CPU usage is high , I would recommend you to change the fan and check if that fails ,you have to checkn the heat sink issue in the processor Fan .
Thanks and regards
Aboobackers
Internet explorer Expert
Nov 28, 2010 | Computers & Internet
Is my cpu getting to hot my cpu fan runs in high speed a lot. do i need a bigger fan or my cpu is going bad.
Neither.
Turn the computer off.
If it is a HP laptop, remove the battery.
Disconnect the AC power.
Buy a can of compressed air, and give your computer a "blow-job",
to blow all the dust away from the heat-sink on top of the CPU,
and also, if it is a desktop, from inside the power-supply.
A layer of dust is a layer of insulation, preventing the heat-sink on top of the CPU from "radiating" the heat away from the CPU. So, your motherboard is detecting that your CPU is "too hot", and automatically speeds-up the cooling fan, to try to move the heat.
Nov 17, 2009 | Office Equipment & Supplies
Pentium 2 motherboard 10 common problems
Windows XP requires at least a pentium III cpu to run. Sorry.
Feb 10, 2009 | Intel Motherboard
MLTIPEL PROECESS EROOR
sounds like your fan on your cpu is almost taken a dump common prombelm you better change it before it over heats and takes your cpu out ... lala linda
May 14, 2008 | Dell Delta Electronics CPU Processor Fan...
Computers & Internet Logo
134 people viewed this question
David Payne
David Payne
