Question about Samsung DVD-P421 DVD Player
Dvd region settings - Samsung DVD-P421 DVD Player
I bought my dvd player from Malaysia but I am using it in Middle East where I am currently residing. Initially, we are able to play all dvds (which we bought original) but suddenly, it kept popping a...
Are you using WMP or any third party players to play the dvds ?
I suggest you to check if the DVD region code is set to one (US) or not. If not, change it to one.
The region can only be changed five times, before its set permanently.
How do I change my DVD region?
DVD movies are encoded for different world regions, and your DVD-ROM drive must be configured for the appropriate region in order to play the DVD.
If you have DVD-decoder software installed on your computer, you can usually change the DVD region setting in the DVD decoder program. Follow the instructions in the program's Help file for changing the DVD region setting.
If you have a software or a hardware DVD decoder installed on your computer, you can use Device Manager to change the DVD region setting in your DVD-ROM configuration:
1. Click Start, right-click My Computer, and then click Properties.
2. On the Hardware tab, click Device Manager.
3. In the list of devices, double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
4. On the DVD Region tab, make the desired changes.
You must be logged on as an administrator or be a member of the Administrators group in order to change the DVD region.
Note that the DVD region for most DVD-ROMs can only be changed up to five times, and the number of changes still available is located on the DVD Region tab. If the tab shows that you can only change the setting one more time (Changes remaining = 1), you won't be able to play DVDs that use a DVD region that is different from your last selection. If you run out of opportunities to change the setting (Changes remaining = 0), contact your DVD-ROM's manufacturer to reset this value.
Also install DVD decoder as an issue with codec or DVD decoder could even cause the issue with DVD region code.
http://www.microsoft.com/windows/windowsmedia/player/plugins.aspx (Also applies to Windows 7)
Mar 26, 2011 | Vacuums
What does check regional code mean?
It means your DVD player has a different region code to the disc you are attemting to play.
DVD's and most DVD players have a region code corresponding to the country/region in which they were purchased. The region code printed on the disc must match the region code of the player, usualy found on the rear of the unit or in the manual. Only players set to code 0 or 9 are able to play all regions, a setting of 1- 6 is most common. 1 = USA 2 = Europe etc.
It is often possible to set your player to code 0 or 9 enabeling you view all region DVD's.
May 16, 2010 | LGDVB418 DVD Player
Region hack code for samsung dvd-p241
You can try to use this tip, which is generally used for all these Samsung models: DVD-709,DVD-809,DVD-909,DVD-511,DVD-611,DVD-615,DVD-811,DVD-M105,DVD-M105 E,DVD-M108,DVD-M203,DVD-M204,DVD-M205,DVD-M305,DVD-M405,DVD-P233,DVD-V530. I think that P-241 is about the same of P-233, which is unlocked with this tip. You can try, and then answer me if worked.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT then the following codes for the required region the player is already set to (region you bought the player in) do not confuse this with the A-B button:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
On some models, you will have the ability to disable Macrovision, but you will have to turn off the Quasi-PAL option and set the SCART output type to Video rather than RGB.
Jul 09, 2009 | Philips Magnavox MWD7006 DVD Player
Wrong regional disc
Hello mperona,
The reason you are receiving this message is due to the region settings on your dvd player. Dvd players use region settings to allow them to only play dvd's from certain parts of the world. Your dvd player's region settings do not match the region code of the dvd disc.
The only way is to make your dvd player multi region....you will need to post the make and model of your dvd player so I can search for a solution that will work.
Thank you for choosing Fixya!
Jun 14, 2009 | GPX D1816 DVD Player
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
Dvd region
if you reinstall windows it will reset firmware...better option download and install any dvd (software "any dvd")this will allow any region to be viewed..so dont have to set region any more.
ps I wouldnt of set region code to any particular region cos of the fact you only get so many tries before it locks and sometimes its permanant if I was gonna do anything it would be to flash it with region free firmware.
Jan 06, 2009 | HP Pavilion dv6000z Notebook
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Unlock sony DVP-FX720
The problem may be you are trying to play DVDs from a specific region (Europe) and the player is set for another region. Region code errors will show up as "no Play" or 'region" Check the manual to see how to set the player to Region 0. A region machine will play any DVD. Sometimes the setting is on the menu - usually in the set-up screen under "region." I have re-set all my Phillips players to become Region Free through the menu.
Aug 22, 2008 | Yamaha DV-S5450 DVD Player
Changing the DVD Region code
since the changes remaining is set to 0, sorry to say that you cna no longer change this to a different regional setting, unless you reinstall the OS,
chances are you have selected the region previously, or somebody else.
The world is split up into 8 DVD regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Old DVD-ROM drives came with a firmware level RPC-1. Software protection was used to control which region is played.
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
How to bypass DVD region code protection ?
As we've said, a lot of newer drives are RPC-2 drives these days. Some of these drives don't allow raw access to the drive until the drive firmware has done a regioncheck. But some RPC-2 drives DO allow raw access, so in some cases it is quite possible to use a special software to bypass the protection:
The first solution is free VideoLAN player: click here to download VideoLAN. It might take a long time to initialize DVD. So just pop the disc in your drive and try it out, while you get a coffee.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition as shown below:
or you can install one of this program:
In WinDVD: if a DVD from a region different than the default one is tried to be played, the dialog box for changing the DVD region code should appear. If that dialog box do not appear, check the region code set in the software:
Click Start, All Programs, Intervideo Win DVD, and Intervideo Win DVD.
Right-click the Win DVD window and select Setup or Properties.
Click the Region tab and check the region code selected.
If there is a 0 in the Changes Until Permanent field, the DVD region code will not be able to be changed again.
If a number from 1 to 4 appears in the Changes Until Permanent field, add a mark in the checkbox of the desired region and click OK. The new region will be set up.
In PowerDVD: the first time you insert a DVD title, to be played on PowerDVD, a small dialogue box will appear. It will set the region code to match that of the DVD title you wish to play. After this the program will be set. However, if you have a region free DVD-ROM drive, you have the option of playing DVD titles from different regions. PowerDVD will allow you to change the region code setting up to five times, and then it will be locked on the region you have listed on your fifth and last change. At that point you will only be allowed to watch DVD titles from that region. To change the region code, from the original setting, just insert the DVD title in your DVD-ROM drive and run PowerDVD. When the software recognizes that the disc is from a different region than what was previously set, a dialogue box will appear. For this example, the Current Region is Region 1. After changing from one region to another, I will have four changes left. The program detected the disc I inserted was from Region 2, so it selected this option. Once I click OK the Current Region will be changed to Region 2 and the DVD title will play.
hope this helps dont forget to mark my solution pls
Aug 07, 2008 | Microsoft Windows XP Professional With...
Trying to change region to 2 but it has locked me out is there a code i need
you can only change ur region codes a few times then ur drive becomes locked to the last reset.then youll need to reflash ur drive with firmware.theres a program u can get(free)called any dvd which gets around region codes.
I personally would reflash firmware.this sets drive to "0" which is all regions.
simple precedure.locate firmware,download it,write it to a cd,insert cd which then reflashes auto.remove cd.
Mar 26, 2008 | HP Pavilion dv4000 Notebook
Samsung DVD-P421 DVD Player Logo
26 people viewed this question
Henry  Thomas
Henry Thomas
