Question about Vehicle Parts & Accessories
My engine on my 1996 Toyota 3.0 A/T diesel surf cut out ond would not start. replaced fuel filter with no luck. I expect a faulty spill valve relay or the ecu. Can I supply power direct to the spill v
My 1996 Toyota Surf with 3.0, 1KZTE engine, A/T cut out for no reason. sometimes the engine start again but cut out after a minute or so. I have checked the fuel pump, replaced the fuel filter with no luck. I susspect a faulty spill valve relay or the ECU. Can I supply power direct to the spill valve to get it going again to enable me to do a proper fault finding?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 71 Answers
If you do that it might start... and the whole engine would be "kaput"
so its better if you tow it and take it to a garage
Posted on Jan 14, 2014
3 Suggested Answers
wrenchtec312
  • 884 Answers
SOURCE: just a faulty fuel pressure sensor or more serious?
It's possible it's a wiring or PCM issue but it's pretty likely the sensor itself.
Posted on Aug 14, 2013
Testimonial: "thanks for the positive encouragement. changing sensor was a reasonable attempt but unfortunately code keeps popping up once in a while. Will schedule diagnosis at dealer."
  • 101 Answers
SOURCE: bought a 1992 chevy Silverado 4.3 liter that's
only thing I ever noticed when running and electric fuel pump on a carburated motor is that it can over power seals,gaskets and o rings. (so it could be running rich...or lean (i forget which is for to much fuel))
may need to rebuild the carburetor, or simply have it adjusted? im not sure tho.
but this only my suggestion
Posted on Nov 01, 2013
No power from take off, sluggish
Changed your fuel filter lately? Deisel motors take a regular filter change as they collect water in the fuel and become clogged leading to bad performance and eventualy a no start condition.
May 23, 2014 | 1996 Toyota Hilux
Does a toyota hilux surf 1995 diesel have spark plugs and points as in the days of yore??
Diesel engines don't have spark plugs. They use compression and heat to fire the diesel. Most diesel engines have glow plugs which are designed to preheat the combustion chamber to help burn the diesel fuel when you start it up. Hope this helps.
Aug 14, 2011 | Toyota 4Runner Cars & Trucks
A4 Diesel estate, intermittantly starts but cuts out immediately. Orange Glow Plug warning light is constantly flashing.
dear . you have water mix with diesel . dont start again . replace diesel filter connect fuel from out side , if you find injector cleaner try use it , after replace fuel filter try to put 50mm engine oil in fuel line . for lubricate and remove rusty.
Jul 26, 2011 | 1996 Audi A4
How to bleed the air from the diesel fuel filter
You have to take the filter of and then fill it up with fuel then replace filter without spilling any fuel out to cause more air to get in the line. When you try to crank the car or truck over it may take a few trys but it should start after a few trys.
Dec 27, 2010 | Toyota Xtracab Cars & Trucks
Surf 1KZ-TE Diesel wont fire
Typically, the glow plug light not coming on indicates that you have some bad plugs or poor connection. You need to replace the plugs and check the wire connections. It is interesting how picky diesels are when they aren't warm.
Hope this helps.
Jan 05, 2010 | 1995 Toyota 4Runner
My 93 hilux surf turbo diesel has started to run a bit rough, not too bad but i have noticed it, i recently had the glow plugs and cold start relay done, but this has had no effect. also uses more fuel....
You may want to add some diesel fuel conditioner.
This is most likely from dirty injector nozzles.
You could also try some automatic transmission fluid in your fuel (about 1/4 quart or so)
That sometimes works.
It may also help if you change your fuel filter regularly.
You may also want to do a compression test on your engine to make sure your engine is in good shape.
There are lots of variables, but I would try injector cleaner first.
Tim
Apr 16, 2009 | 1993 Toyota 4Runner
(TOYOTA SURF 1990 TURBO DIESEL) No diesel coming out of fuel pump
If it has glow plugs or an intake heater you will need to disable the circuit. Then you can use a small amount of ether to spray into the air cleaner.!!! If you spray too much and/or Dont disable the circuits you can damage the motor!!! When you spray the ether, if the engine starts and stalls then its not getting fuel. This could be related to the fuel pump, injection pump, the fuel system loosing its prime(fuel line leak), fuel shut-off valve or solenoid. If it doesn't start then it could be related to your timing, valves or maybe compression.
Feb 10, 2009 | 1987 Toyota Cressida
Toyota Surf Diesel starting problem
Injectors could be blocked but i would go with an injector pump or fuel pump.
Jan 20, 2009 | 1995 Toyota 4Runner
Motor not running
The problem was a electronic box which controls the multi valve system on the fuel pump not the ERPS. The box had lost it's earth contact. These motors don't have a cut off solenoid like older diesels, a lot of trial and error to find.
Now a happy fellow.
Regards Ross
Dec 15, 2008 | 1994 Toyota Land Cruiser
Vehicle Parts & Accessories Logo
66 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
