Question about Crock Pots & Slow Cookers
Countercraft manual setting temperature
Crofton slow cooker manual
The simple answer is to email serviceuk@tempo.org (the distributors) with the model number (TI-SC-1014 for the 6.5 litre model) and request a manual. I did this and they sent the manual as a pdf within a couple of hours. I was impressed.
Nov 26, 2013 | Crock Pots & Slow Cookers
What is the temperature of low setting and high setting where can I get an instructions for Model KC271B
The manual is available here: http://www.sharkclean.com/manual/KC271B_REV_0804B.pdf . The high and low settings are more like those of a microwave rather than a direct temperature setting. On high, the slow cooker uses full power (35 watts). On low it uses 1/2 power.
I hope this helps.
(In one place it says 34 watts. In another it's 340 watts.)
Jul 01, 2011 | Bravetti KC281HB 8-Quart Slow Cooker
Which will provide the lowest heat? low 10 hours or warm setting. Thanks
The WARM setting is the lowest heat. Here's a quote from the user manual:
"WARM is ONLY for keeping already cooked food at the perfect serving temperature. DO NOT cook on the WARM setting."
This is because at the WARM setting, the temperature doesn't get hot enough to kill food-borne bacteria.
Jan 18, 2011 | Rival 38601 Smart Pot 6-Quart
I have Ronson slow cooker with no manual, it has settings 1,2 qnd auto. Which is high and low, and what does auto setting do>
I also have a Ronson slow cooker.
Instructions from the book read as follows:
- On setting 1 (low), the slow cooker can operate all day and night if required.
- When set to 2 (high), it is very much like a covered pot on the stove. Foods will cook in half the time required for 1 (low).
- When set to auto, the slow cooker will cook on 2 (high) until the food reaches a pre-set temperature, then switches to 1 (low) and maintains a constant slow cooking temperature. Auto is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
I always use the auto setting, unless I don't have as much time, and will then use setting 2.
Sep 15, 2010 | Crock Pots & Slow Cookers
Do you need the meet probe to use the crock pot on the manual setting
No the probe is only used when cooking to a certain temperature and using it on the temperature setting... the manualn works great without the probe...
heatman101
Sep 01, 2010 | Hamilton Beach 33966 6-Quart Slow Cooker
I'm looking for the manual for the Corningware SC-60 slow cooker. I need to know how to set the time and temperature. Thanks!
Couldn't find a manual but here's how you can set the time and temperature: http://www.ehow.com/how_6496690_set-timer-corningware-slow-cooker.html Hope that helps.
Jul 27, 2010 | CorningWare SC60 Slow Cooker
Ronson slow cooker settings
Hi. I'm a Ronson Service Centre in Australia.
I grabbled this blurb from a Ronson Slow Cooker Manual.
On Setting 1 (Low) the Slow Cooker can operate all day and night if required.
When set to 2 (High) it is very much like a covered pot on the stove. Foods will cook in ½ the time required for 1 (Low)
When set to Auto, the Slow Cooker will cook on 2 until the food reaches a pre-set temperature, then switches to 1 and maintains a constant slow cooking temperature.
“Auto” is the ideal setting for someone leaving the house for the whole day as most food will cook for 8-9 hours and be ready to serve when they return.
Nov 24, 2009 | Crock Pots & Slow Cookers
Instructions for bellini slow cooker Have product but no manual. what does the auto setting do?
I see this question is from 2009, but just in case you are still wanting an answer.
On AUTO setting, the cooker (cycle) will begin on highest power and then will aautomatically switch to lowest power once the correct temperature has been reached.
Oct 17, 2009 | Crock Pots & Slow Cookers
Lost Manual - not sure which is high or low
Hi. I'm a Ronson Service Centre.
I grabbled this blurb from a Ronson Slow Cooker Manual. Not the same model, but it has the same settings:
Mar 15, 2009 | Crock Pots & Slow Cookers
Crock Pots & Slow Cookers Logo
23 people viewed this question
Top Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
