Question about Pioneer PDP-505CMX 50 in. Plasma Television
Pioneer pdp-505cmx both red and green lights stay on - no picture - any ideas?
Both the red and green lights stay on when powered on - no picture - just replaced the power supply board as previous codes were two blinking red lights
    Top Expert:
  • Pioneer Master
  • 75,571 Answers
After replacing the power supply board, it is necessary and a must to adjust its Va & Vs voltages. These details will be there on its panel label. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Without adjusting these voltages properly, might make the Plasma Display defective.
Posted on Jan 02, 2014
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
  • 93 Answers
SOURCE: Pioneer PDP-503PU
Very possible,but yet,this might be the manufacturer defect power supply which they will fix it for you free;but before we jump to this conclusion,you need to test it first:
-Unplug the power cords.
-Unplug the media video cable from the box to the tv.
-Check all the pins on the video cable are in place as well as the connectors both behind the TV and the media box.
-Reconnect the media box and TV with the video cable(DVI+VGA in one) and have at least a video component hook up to it(ex. dvd player/VCR or comcast box) be sure this video player is turn on and running,at the same time,be sure it is under the right video input.
If you have tried the above steps but still doesn't work,call 1-800-pioneer Tuesday-Thursday at7amPST and address your issue to them.
Let me know if you have any additional questions!
solutiondoct
Posted on Nov 05, 2008
  • 3 Answers
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
http://stores.ebay.co.uk/Plasma-Parts-UK
hope this helps mark doran
Posted on Mar 17, 2009
  • 11800 Answers
SOURCE: I have a Pioneer PDP-4271HD
Yes, the faulty part is in the power source. But, to be sure, check all the other boards: if the power source has failed the big way it might have damaged other components.
Posted on Oct 21, 2010
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
My Plasma will cut on and be perfect for only a few minutes then shuts off. Any ideas on what this could be? Common problems
Most likely the cooling fan is not operating properly. Gets too hot and high temp cutout prevents catastrophic damage.
Apr 06, 2015 | Pioneer PDP-505CMX 50 in. Plasma...
Cannot decrease vertical size enough using the menu controls. I cannot see the entire picture.
Incompatibility betwen source and tv.Try setting your source right.Set auto on Screen Ratio on either device.
Oct 21, 2013 | Pioneer Pdp-505cmx 50" Plasma Monitor Hd...
How can I connect a coaxial cable to Pioneer PDP-505CMX 50 in. Plasma Television
If it has a coax fitting on the back connect there. If it does not have (means it is a monitor with no tuner) connect with a/v jacks to the correct input (component?) from a box and select that input to use for watching programs----picture will always be better via rear inputs than coax.
If you have questions press the make a comment button here.
Mar 25, 2012 | Pioneer PDP-505CMX 50 in. Plasma...
My pdp r04u media reciver red and green ligth not blinking only stady lit when i hook up my plazma with laptop i get green light blinking no picture just i want to know what happen my pdp-r04u problem
if this is only with the laptop,, you need to replace your hdmi board if its with the cable
and you receive sound and no picture replace the tcon board. if you dont have neither
picture or sound replace the power supply.
for any parts you can order at tvpartsandmanuals. com
Dec 14, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Pioneer pdp 502mx goes to standby no picture after power on
Contact Pioneer at 1-800-421-1404 about getting an in-home power supply replacement. This is a known issue with some plasma displays. Some of you would experience a loud pop and then the power supply fails. You get a red light below the ON button, when you press on, the red light will turn green for a second and then back to red. The plasma display will not turn on after the power supply fails. Call Pioneer at 1-800-421-1404.
Brought to you by http://abstravel.com and http://reservaciones.com
May 23, 2008 | Pioneer PureVision PDP-502 50 in. Plasma...
Pioneer pdp 5080xd
put a pack of smokes direcly in front you wont see the lite anymore
Dec 14, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Problem with Pioneer Plasma
Pioneer has a power supply recall on some models. Do a search and you will find a number at Pioneer and they will replace your power supply for free. The loud popping noise and then nothing is a common problem with these. Hope this helps!
http://www.pioneerelectronics.com/PUSA/Support/Important%3A+Updated+Information+Regarding+Free+Power+Supply+Replacement+for+Certain+Pioneer+Plasmas
Nov 30, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Keeps switching off
Theres an power supply upgrade that Pioneer extended on most of their plasma models, even after your warranty is up. Contact them it cant hurt to try
Nov 17, 2007 | Pioneer PDP-505CMX 50 in. Plasma...
Pioneer PDP-505CMX 50 in. Plasma Television Logo
200 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
