Question about Freezers
Kenmore model 2539284214
Freezer is too warm.
Kenmore upright freezer hot on the sides, stop freezing
Without the model number I'm not sure how to answer your question. Does your model have fans that blow warm air on the outside bottom or a front kick plate? What is your model number? Kenmore has model numbers like this example=> 123.3214567 If the fan has a restriction that causes a lack of airflow it can cause the hot Freon liquid that normally flows around the Yoder Loop inside edges of the freezer door to prevent frost buildup to become very hot because the condenser fan is defective or coils are dirty with dust restricting airflow. If the outside is hot you may have a defective condenser fan motor. That will cause the freezer to ger hot. I am here should you want my assistance....Sea Breeze
Kenmore Freezer Parts
Aug 31, 2013 | Kenmore 14.1 cu. ft. / 399 liter Upright...
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
WHAT IS THE PROCESS IN REPLACING THE GASKET ON MY KENMORE UPRIGHT FREEZER
If it is a push fit gasket it simply pulls out and the new one pushes in to the groove. Warm in hot water before fitting to ease it in. If the seal is part of the door, you have to replace the door as a complete assembly. Rare models have doors that can be taken apart and reassembled with a new gasket fitted but i don't think Kenmore is one of those.
Apr 19, 2012 | Kenmore Freezers
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Freezer ok refrigerator not cold we changed the overload relay model no. 59673503201 kenmore elite
feel door seal after door has been kept closed for a quite a time.If it feels warm at any one spot door seal needs replaced.adrian;;;;
Nov 10, 2009 | Kenmore Freezers
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Kenmore Frost Free Comm. Model #253-23425100 - will not stay cold
Two things:
Either the thermostat has inadvertently been turned up, (too warm) or the gas in the compressor tank is low. If it isn't #1, call a repair tech to replentish the has in your compressor. If that isn't it he will tell you what he thinks it is. Good luck!
Mar 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore
when its running how hot are the sides the starting amps are too high and 1.5 running amps ain't bad now the the cut in cut out are too high if you look on the dial that the mid point settings that's where you should have it not on 1 1 is hot set it on the straight line that's where you should do all your testing colder settings go up not down you could be overheating the compressor by making it come on too quick the freezer should be about -10 or so do you see any gaps in the gasket
Mar 31, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Leakage and warm sides
The outsides should will be warm.  This is normal because the condensor lines run thru the cabinet from about half way up the sides and over the top.  Which is why the you shouldn't have anything stacked on top of the freezer and enough room on the sides of it for air flow.  As far as the water leak, tell me exactly where you see the water and does the bottom of the freezer (inside) have a sheet of ice on it.  If there is ice there then the drain behind the bottom panel in the freezer is frozen over and will have to be thawed out.  Let me know what you find.  If you have further questions I may need the entire model # on the sticker inside the freezer.
Oct 21, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezers Logo
22 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
