My surface 2 wont turn on - Computers & Internet
Try tab Spacebar, if you have the attachement keyboard. Do not repeatedly press the Power On switch. The device was probably put to sleep inadvertently. It should be awaken, but not turned on.
Posted on Feb 13, 2014
Why wont the internal batteries hold a charge ?
You have a problem with the battery or charging line. If you have indication from Windows for charging battery, mtery.aybe you need a new bat
Sep 10, 2014 | Microsoft Surface 64GB Windows RT - with...
MS surface will not turn on
1. Assume battery has sufficient charge
2. Assume no physical damage to unit, liquid, dropping etc
3. When turned 'on' can an updated OS be installed?
4. Any other faults or problems noticed?
5. Remove all peripherals and reboot
6. Go to this link: www.microsoft.com/surface/en-gb/support/warranty-service-and-recovery/surface-wont-turn-on
Good luck.
Sep 01, 2014 | Microsoft Surface RT
Microsoft surface tirns on and logo appears but wont do amything else
To reset your Surface without logging in, please try the following:
1. Attach your Touch Cover / Type Cover
2. Power on your Surface
3. Press and hold the Left Shift key at the Login screen
4. Press the Power icon
5. Press Restart
Your surface should boot to a light blue screen with some options on it.
1. Click on Troubleshoot
2. Click on Reset your PC
3. Follow the prompts. Let me know if this does not work for you.
Mar 14, 2014 | Microsoft Surface RT
Microsoft surface pro black screen
These get stuck- try holding the power button and the volume up for about 10-15 seconds and it should reset itself.
Dec 30, 2013 | Microsoft Surface Pro
Motor wont turn over but starter is trying to just wont fire up
How is the battery and battery connections? New and clean should be your answer. After two years a battery will not be in good shape and corrosion will have occurred between the terminals between battery and vehicle. Have battery checked and clean the mating surfaces of the connectors before you connect it back up. Replace battery if it fails test, charge it fully otherwise.
Sep 15, 2012 | 1991 Ford Explorer
Heater turns on but wont light
Does it have spark ignition or a hot surface ignitor? You can accomplish this by looking on the right side of the burners is there 2 wires or a single wire? Whats the make of the furnace?
Dec 14, 2010 | Heating & Cooling
Heater won't stay on
if it is a hot surface clean the flame sensor
Jan 25, 2009 | Heating & Cooling
Projector problem
I generally fix this by re-seating the bulb housing. Take it out and put it back in. Look for cracking at the base of the bulb on the mirrored surface. It could be a barely functioning bulb that isn't busted, but can't initialize. I would take it to a shop that has the same bub type in a housing and make a quick switch.
Jun 20, 2008 | InFocus ScreenPlay 4805 Multimedia...
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
