Question about GY7constructioncom Red Devil Economy Metal Adhesive Spreader, 6 Blade ER211056
Wire diagram 240 vo stop start switch kedu jd2 unit
Need a switch , kedu electric 564
The McCulloch part number for the switch box is 7200-405266, it can be ordered online or from your local small engine repair shop.
Jul 11, 2014 | McCulloch 4 Ton Electric Log Splitter #...
Need a switch, kedu electric 564
I'm not familiar with this unit but you can replace the switch with any other that has the same or better ratings that will fit the slot its in. You can also relocate the switch to another location like the power cord if you need to, to make it work, as long as you do it safely.
Wiring diagram RUUD UAPA-036JAZ
the condensor gets 240 volts a-c and 24 volts a-c to control contactor. pretty straight forward on this 3 ton unit. the 240 volts comes off breaker box and the 24 volts comes off thermostat and common of transformer.
Jun 10, 2014 | Ruud Heating & Cooling
Headlights wont work
According to my wiring diagram, the headlight switch works a relay which is powered by two different fuses.
I would check the relay for voltage first.
You may need a repair manual to trace the circuits.
Dec 19, 2012 | 1991 Volvo 240
Amana ALE643RBW Dry will not start. I checked the thermal fuse and the high limit thermostat both read 0 to 4 back to 0 ohms. It was jumping around back and forth. Checked the heating coil it read 10...
Hello Dale,
Having checked the thermal fuseto be good i will give you a partial list other things that could make the dryer not start
start switch
door switch
timer
circuit breaker, use your meter set to volts ac and check for 240 vac at the outlet,if 240 not at power outlet check for burnt connection inside outlet or bad circuit breaker
if 240vac at outlet check for 240 vac at terminal block on back of dryer where cord connects,if 240 at outlet but not terminal block replace cord , if burnt connection at terminal block,replace cord and block
finally the motor,manufactures do not publish wiring diagrams online and the only way for me to tell you to use jumper cord to check motor is find the wiring diagram inside of control panel and place one wire on the terminal indicated as neutral on wiring diagram and one wire on terminal indicated on diagram as run winding
firstly though check door switch to have contunity (0 ohms) and the start switch to have (0 ohms)WHILE PUSHING IT IN(the start switch isa momentary contact switch and will only have contunity while its pushed in)
to check timer again use wiring diagram and find chart that shows various cycles and with timer set to a cycle the two wires is says will have contunity will be indicated by a solid black line on the diagram
Good luck, Gene
Jul 26, 2011 | Dryers
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
Kenmoore 70 series dryer wont start
Are you 100% certain the dryer has 240 VAC? Just because a light may light does not guarantee both legs of 240 VAC are hot.
If you measured motor continuity, then you must be able to read a wiring diagram/schematic. Most Kenmore units have a wiring diagram/schematic glued to the back of the rear service panel, or folded and stored in the control head.
I am unable to find a wiring diagram on the internet, but, you have a door switch, and the timer/control.
Use the wiring diagram to trace the signal path's to determine where the failure is.
Let me know if you have any questions and I will do my best to help.
Jan 21, 2009 | Dryers
Need help bad!!!!
try to google it at best but chances are you will need to contact intertherm directly and order one. what is wrong with your unit?
Jan 04, 2009 | Heating & Cooling
Housing for Power Window Switches
you wont find it except a volvo and it may be unavaible by now ,if so try to by a used door panel with it included/try erie vo-vo
Aug 11, 2008 | 1991 Volvo 240
GY7constructioncom Red Devil Economy Metal Adhesive Spreader, 6 Blade ER211056 Logo
48 people viewed this question
Top GY7constructioncom Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a GY7constructioncom Saw Expert? Answer questions, earn points and help others
