Question about Refrigerators
Samsung refrigerator ice maker
Water comes out of door when pushing ice or water
catriver
  • 878 Answers
SOURCE: Whirlpool refrigerator ED22TEXHW01 ice maker
Tammi, you first want to check to make sure the water inlet tube to the icemaker is not frozen shut. Next, get yourself a jumper wire about 4 inches long with the ends stripped exposing the wire on each end. Pull off the ice maker cover, it will pull right off. Now you are looking at the module. On the module, left side, you will see two test points marked V and L. Insert one end of the jumper wire into V and the other marked L. You are now sending 120 volts to the water valve and water should fill the ice maker providing the inlet tube is not frozen over. If it doesn't fill, you either have a bad water valve or module itself. Also check to see if the clips that hold the center gear on the module are not broken. Catriver..post back.
Posted on Mar 22, 2007
SOURCE: ice maker not filling with water
I have a model KSRG25F and found that the solenoid that controls the water to the icemaker was not working. I tested by switching the water dispenser connection to the ice maker coil.
And then had the wife push the water fill in front of the fridge. I had aready changed out the control board in front because I didnt have the flash codes or solid led when simulating door closed. the parts is about $55 and hope that does it. Good Luck
Posted on Jul 05, 2008
SOURCE: ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Posted on Nov 09, 2008
  • 7 Answers
SOURCE: in door water and ice cube not working
Water dispenser is a simple touch switch in door energizing a solenoid water valve behind ventilation grate above refrigerator. Water tube runs down into and ends at ice dispenser chute. Should hear solenoid click at top of fridge when activate water touch switch. Can unhook discharge side of solenoid valve temporarily to prove water output. If water dispenser tube acts blocked it could be frozen where it ends-look up the hole at the bottom of refrigerator control buttons.
Ice maker is totally different system. No clicking when push ice button but ice in bulk tray may mean the simplest of malfunctions: Ice bin not pushed in the last half inch if ice auger not lined up with drive pegs. There are hidden switches behind ice bin that need to be engaged or nothing will happen in the ice maker: no auger noise, no clicking, no new ice making. Ice bin will be flush with sheet metal if it is in the right spot. Also plastic juice rack won't hang properly if ice bin not pushed in all the way.
Posted on Jan 19, 2009
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
Samsung French door ice maker
Sounds like you are getting to much water or the sensor is not Sensing proper temp
Apr 02, 2016 | Samsung Refrigerators
The ice maker makes a loud racket unless the freezer door is open.
You have an object jammed in ice makers path. The freezer door has something on it that is pushing into the ice maker perhaps.
Feb 08, 2013 | Samsung RS261MDBP Side by Side...
Samsung RS265TD Ice maker does not fill with water. After I press test button and the ice maker cycles I manually fill the tray with water and it will eject on next cycle etc. Good water supply on thru...
Hello
Either the fill solinoid is bad or the inlet tube at the ice maker is frozen.
Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Jul 28, 2011 | Samsung RS265TD
Samsung mod rfg297aawp. Just began leaking water from the Ice maker. I have a RO water system. Book said to check the inlet water pressure. I wouldnt think that would cause a continous drip from the maker....
Calcium buildup in your water can prevent the inlet valve from closing all the way. To test simply remove hose from inlet valve that goes to ice maker and see if it keeps leaking. The only time water should come out is when ice maker calls for water. Be sure to shut down the ice maker. Push arm upwards or flip the switch. If keeps dripping than replace inlet. If you have any more problems please feel free to contact me.
Jul 16, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker water not coming out of the outside , no water supply to the ice maker
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer.
Jun 22, 2011 | Samsung RS2630SH Side by Side Refrigerator
We have a Samsung RS2530BBP. The ice maker works ok... water stop coming out... What do I need to do to fix the problem?
My Samsung RS 2530BBP frige Ice maker stop tp make ice.
The water tray stays verticly after pushing the reset button and the water pours in the container instead in the tray. I purchased a new ice maker but it did the same. Any idea how to fix it
Aug 12, 2010 | Samsung RS2530BBP (25 cu ft) Side by Side...
Samsung Ice Maker--Ice block and now no water flow...
Wait a few hours before you jump to conclusions. All depends on the position of the cam.
Aug 23, 2017 | Samsung RF265AA Bottom Freezer French Door...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
In door water and ice cube not working
Dec 19, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
