Question about FUJIFILM FinePix JX250 Digital Camera
Digital camera lens **** - FUJIFILM FinePix JX250 Digital Camera
  • Harrie Jan 02, 2014
    Hi Mohd Halim, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? Is something wrong with the lens? and if, what? Like no focus, or perhaps broken?
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
Re Nikon S220 digital camera. Lens error noted -
A tiny bit of grit can jam the gears of the lens. Sometimes a tap can knock it out. Try this at your own risk. Take out the batteries. Don't hit the camera on a hard surface, just use you hand. If it hurts, that is too hard. Try lens down, then all the sides.
May 29, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Lens error restart camera / lens will not open
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 10, 2010 | Canon Powershot SX110 IS Digital Camera...
(lens error) my camera lens wont go back in
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 19, 2009 | Nikon COOLPIX L18 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Digital camera lens cannot come out. Restarting required
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Feb 03, 2009 | Canon PowerShot SX100 IS Digital Camera
Purchased an eos50e with tamron lens 28-200mm a few years ago, can the lens be used with a digital camera
its not possible to use the lens with digital camera .........but can you be more specific about the digital camera with which you are trying to use the lens
Aug 07, 2008 | Canon Cameras
Fuji digital camera A370 lens sticking
It seems the life of digital cameras are 2-3 years. The camera has lens gear problem. The lens assy fails most on digital cameras with moving lens. The plastic gears in the lens assy. are quite fragile in design and when used regularly, gears tends to wear down and eventually damages the lens movement. Many time a small impact or stress on lens when extended do the same damage. The parts are sold as a lens assy and repair cost may run around $100.
Mar 18, 2007 | Fuji Finepix A370 Digital Camera
FUJIFILM FinePix JX250 Digital Camera Logo
20 people viewed this question
Top FUJIFILM Cameras Experts
Tony
Piyal Perera
Piyal Perera
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
