Question about GE Refrigerators
Need to know where temp sensor is located.
I need to know where the temp sensor is located on my GE SSL27RGRBBS model refrigerator. I need to replace it with the new one I bought. Thank You !
  • GE Master
  • 4,654 Answers
I don't have the perfect answer but most times the sensor is attached to the thermostst control knob and the pobe/sensor is is on the end of a small tube leading away from the contol and has a mounting clip. Inside the fresh cood compartment and behind the control panel.Sea Breeze
Posted on May 21, 2009
Freezer section does not freeze, or make ice, Refrigerator section is below 40 degrees and. Using the Freezer section as my refrigerator which is getting us by. GE mentioned the Temp Sensor needs...
Different models have different locations so you first need to find the equipment id tag and give us the model number from that tag so that we can look up the documentation on it.
Aug 28, 2011 | Refrigerators
Hi, I have a GSS201EMD and have had the service tech here 3 times as the refrigerator part of the side by side is not cold. He has replaced the mother board 3 times to no avail. I checked this morning and...
I am having same problem. Freezer works fine but refrig will only go to 40 degrees verified multiple ways with 3 different thermometers that have been checked for accuracy. GE has been out twice and replaced control board and temp sensor but same problem, Did not notice where refrig temp sensor was located. Can anyboby tell me where it is?
Jul 23, 2010 | GE GSS20IEM Side by Side Refrigerator
MODEL # GSH22JFTAWW won't go into defrost had board changed out and the element and the temp sensor and temp limit sensor how do you put into defrost mode maunally and what is wrong with it have to...
Which temp sensor did you replace? The one that clips to the top of the cooling coils is the defrost sensing thermistor. The other "temp limit sensor" is thermal cutoff switch that opens the defrost circuit should it get to warm. Be sure you got the right part for this! There are a couple of different temperature rated cutoff thermostats out there and this model uses a pretty high temp rating.
As to your question of manually putting it into defrost, you would need to unplug the refrigerator and disconnect the power ******** of the control board (the only jack that mounts parallel to the board and should be a green colored three wire connector. The terminals on the board should be labeled "comp", "line or L" and "def". You will need to put a jumper wire between the line and def wires on the wire connector (not on the board). Plug the fridge back in and your defrost circuit should be energized.
Good luck with this!
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE side by side refrigerator that keeps blowing the defrost heater element. MODEL # TFT22JWDA WW SERIAL # TZ264141 I bought it from a GE dealer about 5-6 years ago. It ran fine for 3 years,...
In my GE side-by-side there is a defrost temp sensor located near the top of the evaporator coil. I think the control board uses that temp sensor to know when it should be done defrosting.
On the schematic of my fridge (link below), the defrost thermistor is part number 240 in the diagram (not part number 241, which is a different temp sensor located adjacent to the one you want)
http://www.partselect.com/ModelFrames.aspx?ModelID=361233&ModelNum=GSS20IEMDWW&mfgModelNum=&ManufactureID=2&Selected=00113321i06&Position=2&mfg=GE&Type=&Mark=2
I don't know why the defrost element would fail immediately other than incorrect supply voltage or just a bad defrost element.
Jul 28, 2009 | Refrigerators
Turbo cool will not turn off in GE side-by-side refrigerator. Replaced circuit board...still stays on
There are three temp sensors in my GE side-by-side model GSS20IEMDWW (two in the freezer and one in the fresh food side). Replacing the temp sensor in the fresh food side was enough to allow the compressor to finally turn off.
For me, the problem manifested with an iced-over evaporator coil inside the freezer compartment. Since the compressor never cycled off (presumably because the temp sensor was providing faulty data about the temp inside the fresh food side, thus causing it to continually attempt to cool), the coils were constantly chilled. Eventually the ice on the coils would block the air flow and the freezer side could no longer freeze
I purchased a pair of inexpensive thermometers from a kitchen store and put one in the freeze and one in the fresh food side so I could occasionally look at the temps to see if it made sense for the compressor to be running - ie, was it really a warm-enough temp for cooling to be required, or was the computer reading faulty sensor data.
Six months later I also needed to replace both temp sensors in the freezer compartment. My refrigerator is about seven years old. I would recommend replacing all of the temp sensors just to rule that out.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GSS20IEMDWW&mfgModelNum=&fkMfgID=2
Your model may be different, but this will give you an idea of part numbers and relative locations of the parts.
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Doesnt get cold
Ok, you will need to replace the Thermistor. This is a temperature sensor that is damaged. It is unable to register a true temp.
May 28, 2009 | GE Refrigerators
Refrigerator keeps freezing up. Replaced defraust heater still froze up in about 4 weeks. Tried to replace main board WR55X10037 WITH WR55X10656 BUT THE NEW BOARD DOES NOT KICK MY COMPRESSOR ON. GE SIDE BY...
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side refrigerator defrost problem
CHECK THE DEFROST HEATER FOR CONTINUITY. IF IT IS O.K. CHECK THE ELECTRONIC CONTROL FOR A FAULTY SOLDER CONNECTION ON THE DEFROST RELAY. THE ELECTRONIC BOARD SHOULD BE LOCATED ON THE BACK WALL OF THE REFIGERATOR BEHIND AN ACCESS PANEL.
Apr 08, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
