Question about Echo 3 TE SL7 3 New Electric Scooter by Shoprider
Altea 4 stopping an alarm going of
It goes along then stops and alarm go's of i turn it of and on then goes along and stops alarm going of
  • Echo Master
  • 1,263 Answers
Hi, normally this is a loose connection.... Could also imply the throttle is worn , try pushing the lever in the upwards or downwards direction.. Does it cut out ?
Regards
Rob
www.gewizrepairs.co.uk
Posted on Mar 06, 2014
SEAT BELT SENSOR ALARM GOING OFF IN SEAT ALTEA
will need to inspect,test
and possibly replace that faulty seat restraint sensor
Oct 10, 2016 | 2010 Seat Altea XL
Alarm goes off installing battery in Nissan 350Z
Try leaving key in door or ignition turned on to shut down the alarm...
Jun 09, 2015 | 2005 Nissan 350Z
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
Key won't come out of ignition, car won't start, panic alarm goes off when I try to start it
Sounds to me like you need a new ignition switch. Take the vehicle to a mechanic and have them further evaluate.
Jan 24, 2014 | Volkswagen Cars & Trucks
Need a manual or instructions for mt watch please!!!
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
Have fun :)
May 04, 2017 | Watches
Alarm is going off how do I stop it
The best temperature is the midpoint. Typically 3 or 4. The alarm will go off once the temperature goes down to the freezing point.
May 05, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Car alarm goes off after locking the car.sometimes ten minutes smoetimes three hours after but it still goes off ive disconnected the alarm horn for now but still get the siren noise.i dont know what to...
How old is the alarm? If you have glass breakage detection or motion sensors installed one of these could be faulty. If the alarm is more than a year old and it's an after market alarm it is possible the alarm is faulty and needs to be replaced. There is a fuse in the power supply line, usually running along the firewall between the power point and the alarm. Remove this fuse and the alarm should be deactivated but the ignition kill switch will not be active so you can use the vehicle and the siren will stop going off.
Sep 09, 2009 | Vehicle Parts & Accessories
Car alarm
Try this:
1.Get in the car
2. Closw the door
3. Disable the alarm sensor
4. Activate the alarm
5. Wait 30-35 sec
6. Get out of the car
7. Stop the alaram
8. Get in the car
9. Put the key on the position II, without starting the engine
10. Push the button READ
The alarm led must blink. Then you alarm is reset.
Sorry but my english is not very good, i'm from Romania, i hope you understand
Aug 08, 2008 | 2002 Volvo S60
Aqualite stopwatch alarm
To set time:
1) Press "Mode" button until Time is displayed.
2) Press and hold "Lap/RST" button until seconds display starts flashing.
3) Press "ST./STOP" button to change selected entry.
4) Press "Mode" button to change from seconds>minutes>hours>date>month>day of the week>time format>date format
5) Press "Lap/RST" once you are done to set the time.
To set Alarm time:
1) Press "Mode" button until ALM is displayed.
2) Press and hold "Lap/RST" button until minutes display starts flashing.
4) Press "Mode" button to change from minutes>hours (remember to cycle through for AM or PM
5) Press "Lap/RST" once you are done to set the alarm.
To toggle alarm sounds on and off:
2) Press "ST./STOP" button to toggle alarm sounds on or off (shown on display)
3) If alarm sound is shown on display, alarm will go off every day at the selected time. To turn off alarm once the alarm sounds, simply press "ST./STOP" button on the watch.
Feb 11, 2008 | Watches
Echo 3 TE SL7 3 New Electric Scooter by Shoprider Logo
77 people viewed this question
Top Echo Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Echo Health and Beauty Expert? Answer questions, earn points and help others
