Question about Microsoft Surface 2 with 32GB
My surface 2 will not turn - Microsoft Surface 2 with 32GB
Can a Microsoft Surface 2 screen be repaired locally?
Ask your local repairer, not sure where you live sorry so i can find out, im from australia
Nov 20, 2015 | Microsoft Surface Pro 2
Dont f9999 know my password is anyone please going to help?
What is your question? Did you forget your password to open your Surface? If so, please follow the directions in this link.
Microsoft Surface Tablets
Feb 14, 2015 | Microsoft Surface 2 with 32GB
How to add Netflix app to surface 2 tablet
If you have a Surface RT you can only go through the Windows Store and search for "Netflix", then install it. You can also always just to go www.netflix.com from your device and log in to enjoy your Netflix.
If you don't have the RT version, you can just download the Netflix application from www.netflix.com and run it to install.
Happy Netflixing!
Feb 10, 2015 | Microsoft Surface 2 with 32GB
Cannot connect my AL300 3G to my new Microsoft Surface 2
Surface 2 have drivers?
If so, then if u can get into I, u may be able to try and install them, if it's not the Intel ones
Then I guess the best option I can think of would be, if your wanting to use the data sim, have a look online and see what 3g stick is comparable with surface 2, then from there
You could get an unlocked one or same brand as simcard provider and try that,
Sometimes there's comparability issues with these things.
Hope this helps somehow :-)
Jan 16, 2015 | Microsoft Tablets & eReaders
MS surface will not turn on
1. Assume battery has sufficient charge
2. Assume no physical damage to unit, liquid, dropping etc
3. When turned 'on' can an updated OS be installed?
4. Any other faults or problems noticed?
5. Remove all peripherals and reboot
6. Go to this link: www.microsoft.com/surface/en-gb/support/warranty-service-and-recovery/surface-wont-turn-on
Good luck.
Sep 01, 2014 | Microsoft Surface RT
Is there a way I can get my surface 2 to recognise the ANT pen drive for my Garmin Vivofit.
I assume it's not a surface PRO 2 but just a regular Surface 2. The surface 2 runs Windows RT which only runs specials apps designed for it. It can't run software that is made for regular Windows computers. Unless garmin creates specific software for Windows RT I'm afraid that it might never work.
You can attempt the software found here: http://download.garmin.com/omt/express/B/GarminExpressInstaller.exe but I doubt it works.
What you're trying to do it akin to runnign iPad apps on a Mac, it doesn't work before the architecture is different.
May 05, 2014 | Microsoft Surface RT
Microsoft surface tirns on and logo appears but wont do amything else
To reset your Surface without logging in, please try the following:
1. Attach your Touch Cover / Type Cover
2. Power on your Surface
3. Press and hold the Left Shift key at the Login screen
4. Press the Power icon
5. Press Restart
Your surface should boot to a light blue screen with some options on it.
1. Click on Troubleshoot
2. Click on Reset your PC
3. Follow the prompts. Let me know if this does not work for you.
Mar 14, 2014 | Microsoft Surface RT
Microsoft surface pro black screen
These get stuck- try holding the power button and the volume up for about 10-15 seconds and it should reset itself.
Dec 30, 2013 | Microsoft Surface Pro
I have the Surface 2 and have encountered two big issues. One is that they don't have any apps I want besides basic Windows ones and two is that the form of the tablet always gets changed around when i try...
Check your manual or search on Microsoft forum to see how you can stop the change. Unfortunately with the apps, this is dependant on Microsoft releasing software/apps that work on the tablet.
Dec 09, 2013 | Microsoft Surface Pro
There's barely any apps available for the Surface 2, do I need to upgrade?
This is on Microsoft. Until more third-parties start developing apps for the device, this will not be fixed.
Dec 09, 2013 | Microsoft Surface 2 with 32GB
Microsoft Surface 2 with 32GB Logo
60 people viewed this question
Top Microsoft Tablets & eReaders Experts
thetraveler
Level 1 Expert
Les Morrison
Les Morrison
Ruben Caraballo
Ruben Caraballo
Level 1 Expert
Are you a Microsoft Tablet and eReader Expert? Answer questions, earn points and help others
