Question about Plumbing
Wateridge toilet manual
Leaking cistern goes dry when water is turned off
ftw1952
  • 10319 Answers
SOURCE: when the toilet is flushed the cistern has started
either the valve is full of sediments or needs adjustment
Posted on Mar 10, 2010
  • 102 Answers
SOURCE: Gravity fed toilet cistern-no water feed.
First I would disconnect the supply line and see if I have water to that point. If so, than take apart or replace the ballcock or float valve. If not continue to trace problem backward untill found. Hope this helps.
Posted on May 13, 2010
  • 34 Answers
SOURCE: Dripping overflow from toilet cistern.
there is an adjustment screw ontop of the fill valve assembly. Tighten this down and the water level should stop at a lower level unless the internal mechanism has crusted up.
Posted on Jun 08, 2010
  • 298 Answers
SOURCE: Hi i have a closed
If water is constantly running into the cistern you will need to change the rubber washer in the shut-off valve. Washer kits are available from most DIY stores. Turn the water off at the isolating stop-****. Unscrew the end of the inlet valve (watch out that any springs etc. don't ping out) change teh washer and reassemble in reverse order.
Posted on Feb 18, 2011
  • 112 Answers
SOURCE: Cylpso Toilet Suite D-18156 Slow leak into bowl
You need to replace flapper which is available at where plumbing products are sold,even walmart has them.
Posted on Jun 12, 2011
When toilet is flushed and refills water leaks into the cistern.
Are you saying that water is running into the toilet bowl? If so, check the rubber flapper at the bottom, and the valve (tube standing up).
Mar 29, 2016 | Caroma Home
Tip
FIXING A TOILET THAT WILL NOT FLUSH!!! a simple but very effective money saving...
This simple how to, is based upon most lever operated toilets, with the cistern mounted above the toilet bowl. The make and model of toilet used for this feature is of the following:
Toilet and internal syphon
DUDLEY ELITEDudley S7 Cascade syphon
Problem:
My toilet will not flush, but the ball float valve is working and there is water in the cistern; no leaks present and the flushing lever is not broken or disconnected, what do I do?
Answer:
first isolate the water to the toilet or the main water supply to the house. Bail out the water from the cistern using a small jug or cup, (or you can syphon the water manually using a hosepipe or similar pipe, a towel to cover your mouth, and either a bucket or the toilet bowl) and remove water from the bottom of the cistern with a sponge.
Changing the syphon in a toilet that is not close coupled is far easier as you do not need to remove the cistern from the wall!
Undo the lower of the two large nuts beneath the cistern using a large pipe wrench or pair of water pump pliers, now disconnect the flush pipe and push it to one side.
Place a bucket or bowl beneath the cistern and undo the Nut which is immediately below the cistern (syphon replacing nut), some water may be released by the syphon, take note of any washers that are removed as new ones need fitting when replacing the siphon.
Unhook the lift rod from the flushing lever and remove the syphon.
Inside the toilet syphon, there will be a small plastic piece of sheet called a diaphragm; you can fabricate a replacement using the plastic title cover on a DVD case. Cut this to the exact same size and shape as the original part, and fit this to where the original diaphragm was. This is your new replacement.
Refitting is a complete reversal of removal, be sure to fit any washers (preferably new ones) that you have taken out. Ensure everything is tight but do not over tighten before refilling the cistern
on Aug 09, 2010 | Plumbing
Hissing concealed cistern
The float valve needs adjusted or replaced.
Nov 30, 2014 | Kohler Home
Grohe service
toilet will need syphon replacing. the lid should lift of the cistern, some have the push buttons screwed down to the syphon and to remove them just turn the ring around them anti-clockwise.
Aug 22, 2014 | Home
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Toilet pumps when not in use
sounds as though there may be a trickle of water going in to the pan from the cistern. To check you could turn OFF the water to the cistern, or tie the float arm up. then flsu the water in the cistern so that no more water will trickle in to the loo. Leave it a goodly time, several hours say, and monitor if it still runs for a few mins every hour. Actually running for two/three mins is rather a long time but first i would think you need to eliminate the possibility of the above steady trickle from the cistern.
Nov 06, 2013 | Saniflo & Saniplus& Macerator Pump
Opal 2000 toilet suite, water leaking from around bedding cement. Have marked water level in cistern and bowl with marker and there is no change, water would appear to be coming when toilet is flushed like...
check the donut seal which seals the cistern to the pan, they perish and leak when the toilet is flushed, water runs down back of pan to floor you can check this by drying/wiping with tissue back of pan and flushing you will see if any moisture is running down there by wiping again with tissue and seeing if it is damp.
Sep 04, 2011 | Caroma toilet - water saving Sydney Low...
Cistern leak
The flapper valve(ball)seat is not sealing. Needs a new seat and flapperat bottom of tank. -Ned-
May 26, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
Plumbing Logo
27 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
