Mp3 player will not charge - Audio Players & Recorders
MP3 won't charge
My MP3 player won't charge or turn on [Solved] - CCM.net
ccm.net > Forum > Hardware
Jul 12, 2013 - Hello,Was charging my player, and all of a sudden it stopped. Now i cannot charge it and it will not turn on either, it's a Sansa Fuze. Please help ... Hipstreet mp3 won't charge!
Aug 23, 2015
Philips MP3 won't charge via mains USB
Jun 23, 2015
MP3 won't charge after washing
Sep 17, 2014
My laptop does not recognize my mp3 player [Solved]
Jan 18, 2013
More results from ccm.net
why won't my MP3 player charge? ' Yahoo Answers
Jan 03, 2016 | Audio Players & Recorders
Can u please tell me how to charge my mp3 player Laser 2G ? its new and they told me that it will be charged when i put it in my computer but i tried and i could not even while my computer is charging .
The MP3 player is charged using the supplied USB cable. When you connect the USB cable into the computer's USB port when the computer is switched on.
If the MP3 player still does not charge, try connecting it to a different computer. If it still does not charge then the USB cable may be faulty.
I suggest you take the MP3 player back to the supplier for a replacement. You should get them to test the MP3 charging.
Jan 09, 2011 | Laser MVP-2G (2 GB) MP3 Player
Do i need a computer to charge my m.p.3. player
Hi
yes you need a computer to charge your mp3 player if you do not have a charger for your mp3 player
To charge your mp3 with a computer you should swiych it off then connect one end of a USB cord to the mp3 player and the other end to the computer (just like you want to transfer files)
The screen of your mp3 player will light up and you will see an icon or word indicating that the mp3 player is charging.
Jul 04, 2010 | Philips GoGear SA2825/37 MP3 Player
I HAVE A NEXTAR MP3 PLAYER MODEL MA797 I CAN NOT GET IT TO CHARGE WITHOUT THE DRIVER. I CANNOT LOCATE THE DISC. DO YOU CARRY A DRIVER DOWNLOAD?
I don't know about your model MP3 player, but most MP3 players charge via the USB cable. Just connect the MP3 player to a computer's USB port to charge the player or a USB charger.
Jun 05, 2010 | Nextar MA797-20 MP3 Player
How do I charge the MP3 Player?
Have you got the cable that go's between the mp3 and the computer ?. If you have then that is haw you charge up your mp3 player, you can leave it hocked up to your computer while it is charging.
Feb 23, 2010 | Nextar MA933A MP3 Player
How do i charge it
Three way to Charge you Battery...
1. Charge with USB Cable- Use usb cable and directly connect to you mp3 player, And another attach to the computer.
2. Charge with Charger - directly connect to AC power supply and another attach to mp3 player.
3. Directly Boost - Another way to charge, open your mp3 player and charge your mp3 battery directly (+/-) point with Zapper (zap gun) - It will boost your battery immidietly.
Jan 28, 2010 | Audio Players & Recorders
Charging mp3 player
If your MP3 has an inbuilt Li-Ion battery (e.g. no compartment for a standard/Ni-MH AAA battery), then connecting the player to your computer will normally charge it - this is the case for the PD-6070 'stick' player. Your player will also indicate that it is being charged (or not charged!) via the battery level/power indicator which is located on the top RHS.
Hope it helps!
Dec 19, 2009 | MyMusix PD-6070 MP3 Player
How do i charge my sansa mp3?
  • Step 1:Plug the appropriate end of the USB link cable that came with your SanDisk MP3 player into the MP3 player itself. The port for this cable can be found on the right side of most models of SanDisk MP3 players.
  • Step 2:Plug the other end of the USB link cable into a free USB port on your computer. This will effectively connect your SanDisk MP3 player to your computer.
  • Step 3:Turn your computer on. This will cause your SanDisk MP3 player to automatically begin drawing power from the computer and charging its battery. On the screen, an indicator light will flash yellow while the player is charging.
  • Step 4:Disconnect the cable from both your MP3 player and your computer when the device has finished charging. You will be able to tell when the charge is complete when the indicator light that previously was flashing yellow appears as solid green.
  • Sep 17, 2009 | Audio Players & Recorders
    MP3 Player Not Charging!!! (USB)
    The most common cause is a flat battery. There is a trick to charging
    the battery in these small mp3 players. It wont charge if it is turned
    on, and it won't charges if it's in sleep mode (zzzz). Here what to do...
    1. plug the payer into your USB port. or wall charger
    2. switch thje player on
    3. turn it off by either holding down the play button, or selecting
    "System" from the menu
    4. The screen will go black and the battery will begin charging.
    Feb 15, 2009 | Coby MP-C7092 (2 GB) MP3 Player
    Samsung MP3 not charging
    Get the driver from:
    http://www.samsung.com/us/support/search/supportSearchResultView.do?group=&group_cd=&type=&type_cd=&subtype=&subtype_cd=&model_nm=&dType=D&vType=L&mType=&model_cd=&menu=guides&prd_ia_cd=&acc_ia_fl=&disp_nm=YP-K3JAB&isEqualsY=Y#
    Mar 13, 2008 | Samsung YP-K3 MP3 Player
    71 people viewed this question
     Grubhead
    Grubhead
