Question about Kenmore Refrigerators
Replacing a relay and overload protector with a 3 n 1 hardstart
Replacing a relay and overload protector with a 3 n 1 hard start hardstart came with 5 wires I know the placement of the 3 on the compressor but not sure on the 2 black power wires my relay had a pink and blue wire hooked to it and the overload had a black wire
    Director Badge:
    Uploaded 100 video answers.
  • Kenmore Master
  • 488 Answers
2 BLACK WIRES IS POWER. ONE GOES TO NEUTRAL, ANOTHER TO THE HOT WIRE(LINE) AND IT DOES NOT MATTER WICH YOU WILL HOOK UP AS LONG AS ONE OF THE BLACK WIRES HAS NEUTRAL, ANOTHER ONE POWER. AND BLACK IS GOING TO COMPRESSOR COMMON PIN, WHITE TO START PIN OF THE COMPRESSOR AND RED TO RUN. I HAD ON THIS REFRIGERATOR START AND RUN CAPACITORS, I ILLUMINATE THOSE - THEY CAN NOT BE IN THE CIRCUIT WITH 3 N 1 HARD START KIT. SOME COMPRESSOR HAVE THOSE CAPACITORS, SOME NOT. I DID NOT UNDERSTAND WHY THIS ONE HAD CAPACITORS IT WAS ONLY 1/3 HORSEPOWER. HOPE THIS HELP YOU.
Posted on Nov 26, 2015
  • Kenmore Master
  • 2,183 Answers
Watch this video,it will help you out.
http://www.youtube.com/watch?v=H6xUI7aXY_A
Posted on Jan 02, 2014
carldc3
  • 82 Answers
SOURCE: I NED TO CONECT 3-1 RELAY OVERLOAD CAPACITOR IN MI FRIDGE
first take all the relays and capacitor off of compressor , then attach black wire with terminal on "C" terminal post usually top terminal, white wire with terminal goes on "S" terminal post on compressor, red wire with terminal goes on "R" terminal post on compressor. then take the two black wires one connects to white neutral wire and the other connects to the black power wire if tis fridge has a condensor fan then you will also need to connect it two the two black wires also thanks hope this helps
Posted on Jan 23, 2009
larryyb
  • 291 Answers
SOURCE: i am replacing the relay
your start device has 2 wires connect to it and the cap slides into it unless you have a relay and over load and in that case one wire goes to each
Posted on Dec 12, 2008
Just_Bobz
  • 448 Answers
SOURCE: Wiring hard start capacitor in GE refrig
I would go back to person who gave that advice because just the right touch on that capacitor and YOU my friend will be in the hospital. If this is helpful, please post as such. TY
Posted on Jan 17, 2009
  • 11 Answers
SOURCE: PTC relay on compressor
Try to find the "secret" wiring diagram.  Almost all refrigerators have a hidden paper wiring diagram.  It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan.  While you're in there, it's a good practice to clean the coils.
Posted on Oct 23, 2007
tborn6
  • 700 Answers
SOURCE: I need to
the two power wires go to the incoming power to the compressor, then there should be three other wires that go to the common/start/run terminals on your compressor.
Inteliclean won't turn on
u can hardstart the compressor with a hard start kit, not to expensive, thats if the start relay is ur problem? do u hear any kind of clicking sound?
Feb 13, 2015 | Refrigerators
Solenoid diagram
that sounds like the hardstart relay that energizes the start windings in the compressor . if that or more likely the capacitor fails when it is first energized the compressor will pull excessive amps and cause the overload protector to open until it cools for a minute or two.
Jan 15, 2014 | Traulsen Freezers
The compressor clicks but it stops in like 30 seconds so it does not cool the refrigerator and freezer model # MZD2665hew
It could be the problem with the compressor itself that's why the OLP(overload protector) kicks on after a few second because it sensed high current flowing to its line. You have to check the resistance of the compressor. It has 3 terminal, check the 3 resistance reading using the multimeter to confirm if the compressor is already faulty. It must be more than 2 ohms per reading...
Jdvillanueva
Sep 05, 2011 | Refrigerators
There is a clicking sound like something is trying to turn on, the freezer has quit cooling and now the frig is begining to shut down what can it be?
How To Replace the Compressor Relay The compressor relay is accessed from the lower rear of the refrigerator. The compressor relay is located in the terminal box which on the side of the compressor.
Before replacing the compressor relay, unplug the refrigerator to avoid an electrical shock hazard. Also, if the compressor uses a capacitor, it must be discharged.
The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip.
Beneath the terminal cover is found the compressor relay (labeled "A" below), overload protector (labeled "B") and the electrical terminals of the compressor motor.
Remove the compressor relay by pulling it straight off from the compressor.
Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers.
Inspect the connector for corrosion. If it is corroded it should be cleaned or replaced
Reattach the wire to the new compressor relay and press the relay back onto the compressor terminals. Replace the terminal cover box and plug in the refrigerator.
Aug 18, 2011 | GE GSS20IEP Side by Side Refrigerator
My freezer stopped functioning today. The light is on, there is a noise starting every now and then, there is a click and it stops. After a while the noise starts again. What should I do?
the noise you are hearing is probably the starting relay on the compressor failing and causing the overload protector to cut the power off to the compressor. Try replacing the overload and starting relay.
Mar 01, 2011 | GE 14.8 cu. ft. General Electric Chest...
Not cooling clicking sound refrig compresso and
IT'S MOST LIKELY THE START RELAY/OVERLOAD PROTECTOR ON THE SIDE OF THE COMPRESSOR. UNPLUG UNIT AND PULL START RELAY OFF AND SHAKE. IF SOUNDS LIKE IT'S FULL OF GRAVEL IT'S BAD, OR GET VOLT /OHM METER AND CHECK CONTINUITY BETWEEN THE START AND RUN TERMINALS ON BACK SIDE OF RELAY, WHILE YOUR THERE CHECK CONTINUITY BETWEEN THE BACK SIDE OF OVERLOAD AND WHERE L1 WIRE COMES IN FROM THE HARNESS. IF ALL THAT CHECKS OUT THE COMPRESSOR MIGHT BE BAD OR DRAWING TOO MUCH CURRNET FOR THE FACTORY START DEVICE. YOU DIDN'T NOTE A SERIAL #, SOME OF THOSE MODELS WERE UNDER RECALL FOR THE RELAY/OVERLOAD PROBLEM.
Oct 06, 2010 | Maytag MSD2756G Side by Side Refrigerator
Fridge not cooling fan runs sounds like something around compressor kicking off and on
Compressor not starting. An overload shuts it down if it can't start.
There are either 2 or 3 components that are connected to the side of the compressor that start it. One, the start relay, two (optional on some models) the start/run capacitor) and three the overload protector, which is the thing you hear when it clicks off and after a wait back on.
These components can be removed and tested. Most appliance parts houses would be glad to test them for you.
If they test good then you have a failed compressor. Only a trained tech can handle that problem.
P.S. If this machine is under 5 years of age, do nothing. The compressor comes with a 5 year warranty and you'll have to call your selling dealer for service. They would charge you for replacing start comonents but that would keep your warrant in effect.
Nov 02, 2009 | Refrigerators
Buzzing noise lasting 5-10 sec, occurs every 4 min. Seems to be coming from relay attached to freon tub
Hi, That would be the relay/overload you hear. The "buzzing" is the start device of the compressor, and the "clicking" is the overload/cut-out protector. It may just be a faulty relay/ start device, or it may be effect of a locked rotor in the compressor. You can try to replace the start device and see if that yields any remedy, ( I recommend and use the RCO410 also known as a HS410 3 in1 hard start kit) if it doesn't start it...call a tech, it may need a compressor and some units have a five-ten year warranty on the compressor, check your owners manual under "warranties". Hopefully that's a start for you. Good luck
Sep 29, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerators Logo
134 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
