Question about Gateway MX6453 Notebook
Red light and gets very hot while plugged in
I have a red light on the front of my gateway mx6453it still runs but gets very hot while plugged in
  • JDTec
    JDTec May 11, 2010
    what area gets hot?
    Did you check to see if the fan is working ok?
    Is it the battery that is overheating?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 75 Answers
Avoid putting the pc notebook on soft surfaces like
the bed, on pilo
Posted on May 20, 2009
95 Gran am engine lith blinks and exaust pipe gets red hot runs rough
Should be your catalytic converter is plugged up.
should be replaced
Jun 25, 2012 | Cars & Trucks
I have a 1989 olsmobile delta 88 3 8L front wheel drive Engine runs very rough and about 5 minutes later catalytic converter turn red hot any answers
If the cat is red hot it can only be because it is getting too much air and fuel down there. You most likely have a very large vacuum leak.
Nov 07, 2011 | Cars & Trucks
The transformer box is getting hotter than it usually does. And it does not now give a blue light on the LH light of the pair on the front of the computer, but a pink light. The part is the mains plug at...
hi I guess your battery pack is need to replace thats why your adapter is getting hot due to battery pack leakage and is not charging normally. thanks
May 28, 2011 | Gateway MT3418 Notebook
No power. All power cords checked and tight. With
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Jan 06, 2010 | Gateway MP6954 Notebook
Earlier today I had a Red Power light and only a green wireless light. Now I have no lights when I plug in the 2wire router / modem. Is the equipment dead or is there something I can do besides replace...
Try the following steps:
1. Disconnect the 2wire gateway power adapter.
2. Reinsert the power adapter directly into the wall socket.
3.Remove any power strips or surge protectors temporarily to ensure that these items are not preventing the 2wire gateway proper operation.Note: Make sure that you are using the power adapter that came with your 2wire gateway.
4. Plug the power adapter into a different wall socket in another room.
5. Press the red factory reset button if available.
6. If the power light is still red, then you will need to replace the 2wire gateway.
Nov 27, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Will not power up. trying to turn on and just the red battery light flashes
blinking red light with battery icon means that you are running out of battery power. if the computer is plugged in to the wall and it still does the same thing you may have to replace the ac adapter or charger. the charger should have a green light on it to indicate it is getting power.
Sep 29, 2009 | Gateway Computers & Internet
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
Indicator lights
it's probably the battery charging pilot light
Oct 21, 2008 | Gateway MX6442 Notebook
Laptop won't power up
when u get power on of your laptop .u seen Red/orange light blink 4 times on front panel.it means your laptop battery is not getting charge.please get charge for minimum 6to 8 hrs & then try to on .if y u laptop battery is get charge u r laptop will started on (also confirm your A/c adapter is working .green light is display on front panel it indicates charging on )
Jul 09, 2008 | Gateway MX6124 Notebook
Gateway MX6453 Notebook Logo
95 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
