Error code e08 hoover - Washing Machines
4 Suggested Answers
  • 1768 Answers
SOURCE: Hoover washing machine - door won't open and drum
1. please provide the model number for the washer
2. this is a timer error code and it seems that it locked the door during the spin cycle.
There may be a malfunction sensor or you will need to unplug the washer to reset the washer to complete the cycle.
Something electronic has caused the washer to shut down to protect the electronic circuit. You may have a defective timer.
Posted on Mar 13, 2010
Testimonial: "Thanks for your help, it's working fine now :-) "
richroth
  • 9472 Answers
SOURCE: Hoover WMH168D error code E08
E08 = Tacho fault
The tacho coil is on the motor and is fitted at the opposite end of the drive belt where the carbon brushes are. This error says something is wrong regarding the tacho coil but it doesn't specify exactly what. Possibilities are varied so unless you know what you are doing, and unless you can see something obvious like the coil has come away from the motor or the motor or drum has seized up it is probably better to call in a professional.
Resistance readings for tacho coils are usually quite high, so if you don't have a sensitive enough meter it could appear to be open circuit when in fact it's reading over 150 Ohms or more and may be ok.
In conjunction with a magnet fitted on the end of the armature shaft each time the motor does a revolution it can be counted by the software or pcb through the tacho coil. This information is used to judge and control the speed of the motor at all times.
If the coil is open circuit the washing machine would lose al control of the motor and in the past the motor would often spin uncontrollable causing damage to the washing machine. These days if an open circuit or missing tacho coil (they can fall off the motor) is detected the machine will stop working and report an error code.
Posted on Oct 18, 2012
dtcparkdene
  • 3 Answers
SOURCE: Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Posted on Sep 18, 2013
Tip
Xbox 360 RROD E08 / error code 0020
x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020
on Mar 25, 2010 | Microsoft Xbox 360 Console
E08 on my dryer
Search online for "error code E08 + your make & model"
Aug 23, 2015 | Hoover Dryers
Hover OPD 714 D 7kg . What does E08 mean
http://service.hoover.co.uk/manuals/OPH714D_1.pdf
user manual
http://www.whitegoodshelp.co.uk/hoover-error-8/
here is a description of the common error your machine has
and how too solve it
hope it helps you...
Mar 04, 2015 | Washing Machines
Hoover washing machine showing H05 error
Error code: h05 coming up when i switch on the tumble - Fixya
www.fixya.com/support/t8443068-error_code_h05_coming
Feb 24, 2011 - Question about Washing Machines. Open Question ... SOURCE:Hoover washer/dryer VHW854D SHOWS ERROR. I have exactly the same ...
I have a 3 month old Hoover washing machine [DYN10146P ...
www.fixya.com > Forum > Washing Machines
Aug 11, 2011 - I have a 3 month old Hoover washing machine [DYN10146P] with aH05 fault. ... Have just looked in the service manual, it reads: Error 9 - Cancel the programme by returning the selector to the OFF .... show e-60 on screen.
Hoover and Candy Washing Machine Error Codes - YouTube
? 5:00
https://www.youtube.com/watch?v=kzhlvB2LjXg
Sep 1, 2014 - Uploaded by eSpares
Does your Hoover or Candy washing machine stops before .... I have a question: My Hoover displays the error code E08. what can I do to fix it?
Nov 18, 2012 | Washing Machines
I posted this elsewhere by mistake, I have a Hoover Optima which had an E08 fault, the forums suggested a Tachometer issue. I fixed the fault it was just the motor brushes. i made a video including testing the tacho and changing the brushes that cost me a tenner. easy fix hi I had this fault google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on you tube http://www.youtube.com/watch?v=xYn-f78GB4U if its any use.
Oct 17, 2012 | Hoover Washing Machines
E08 fault code
Hi.
Al was correct in stating that a service call is needed. E08 is a motor error. The control boards detects an incorrect input from the tachio-sensor attached to the motor. The motor, mechanics, wiring and control board must be tested.
Regards.
Ginko
Dec 06, 2011 | Hoover Washing Machines
Hoover washing machine - door won't open and drum won't spin, error displayed is e08, ideas anyone? Thanks :-)
Mar 13, 2010 | Washing Machines
Hoover error E08
Oct 02, 2009 | Washing Machines
Washing Machines Logo
199 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
