Question about Skil 487 Jig Saw
WHAT BLADES ARE COMPRABLE TO MY OLD SKIL JIG SAW MODEL 487?
THE (OLD) CURRENT BLADE HAS TWO HOLES FOR THE SET SCREWS.... THE NEW SKIL BLADES HAVE A "U" END TO THEM... WILL THEY WORK?
5 Suggested Answers
  • 2428 Answers
SOURCE: blade broken down in jig saw
This may sound to simple and not mean to be funny or insulting but why can,t you just take the screw out that holds the blade in you would have to do this when ever you needed to replace or change to a different blade Idon,t know mabey im missing something that your trying to say im not sure
Posted on Dec 04, 2010
  • 29 Answers
SOURCE: broken blade inside jig saw. How to remove?
what type do you have?? is it a easy in or do you need an allen key to install and remove either way if you can hold it open try a tip of a nail file to wiggle it out or there should be an allen key or screw to remove the front its very small that will allow you to remove the broken piece....happens to me alot
hope i was a help
kirkx
  • 2019 Answers
SOURCE: Can a jig saw rip fence (Skil rip fence model No.
Yes, but not very well.
That is because the fence ridge is intended to rest on the edge of the wood, and if you want a circular cut, you need to attach to the center of the arc.
In order to do that, you would have to turn the fence over so that the ridge pointed up and did not impact the surface of the wood.
Then you need to attach a point of radius.
The best way I can think of doing that would be to drill a hole through the sheet metal, near the ridge, and near the shaft.
Then use a small nail or pin through this hole you drilled, to stick into the wood surface far enough for a reasonably steady pivot point.
Best I can thing of.
But you could also just use a piece of wire to the rotation point pin.
Posted on Mar 11, 2011
  • 142 Answers
SOURCE: How do you change a blade in the Bosch Jig Saw
Pull the black knob on the top front of the handle up and turn it clockwise to tighten and counterclockwise to loosen. I'd turn it counter clockwise at forst just to make sure it's loose enough to accept the blade when you start.
Posted on Dec 16, 2011
How to change scroll saw blade
MAKE unknown to us we have no idea where to look or send you
Jun 25, 2016 | Saws
While I'm cutting a 2x4 the blade stops or catches on something? It's happened so many times.
Dull Blade most likely
Wrong Blade maybe
Wrong cutting depth setting on blade
or the way your using the saw
Oct 29, 2014 | Skilsaw "5150" Circular 7 And 1/4 Inch
Jig saw blades wont stay in.
loosen it more before you put the blade in.
Mar 16, 2014 | Skil Saws
How do you change a blade on a Skil 4280 jig saw?
It is REALLY easy, when you know how. There is a black piece, the larger one, near blade insert...lift it and VOILA, you can insert or remove blade easily. I lost manual and spent forever trying to put blade in. Hope this helps.
Sep 22, 2013 | Skil 4280-01 4280 Variable Speed Jigsaw...
How do you change a blade in the Bosch Jig Saw Model 1587 AVS
Sep 01, 2011 | Skil 1587AVSK - Bosch Jig Saws Power Tools
Model JS250Q type 1 Skil Saw - cannot seem to get the blade to stay in and cannot find the manual - could you possibly send a pic of the clamping mechanism?
product diagram is at this link;http://www.ereplacementparts.com/black-and-decker-js250q-type-variable-speed-jig-saw-parts-c-4167_4262_11752.html. I suggest you remove the screw you use to tighten the assembly, install your blade and if there is a hole in the blade, try to visually line up that hole with the screw hole. Generally ,that screw has a nose that will pass the blade first, then tighten the clamping mechanism.
Aug 03, 2011 | Garden
I need directions on how to change the baldes on a reciprocating saw.
There are 2 types of clamps that hold the blade in that type of saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
Skil 487 Jig Saw Logo
123 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
