Question about Mitsubishi VS-55707 TV
Take Apart Unit
I need to take this beast apart to get it out of my basement. Any easy way? the front bezel is off and still can't get it out??
    Top Expert:
  • Mitsubishi Master
  • 75,581 Answers
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Disassemble procedure to many popular brand TVs are given in detail, with illustrations. Do a search by brand name.
Posted on Jan 02, 2014
How to remove instrument cluster
Take the dash apart like you are removing the stereo. Then the black bezel in front. 3 screws on the top recessed into the bezel in front of the instrument cluster. 2 behind the air conditioner/heater panel and it should slide out. 4 more screws holding the instrument cluster in place.
Jul 14, 2014 | 1990 Toyota Pickup
Menu screen keeps popping up stop
In my case I took the monitor apart and replaced the small plug on the Menu switch unit with soldered connections. This requires you to have a very small soldering iron, mine has 1mm tip. The problem seems to be caused by the connections in this plug, or the other end on the On/Off board making intermittent or poor connections. This is not a job for the faint hearted. Getting the monitor apart is answered elsewhere but the following is a brief summary. With the monitor facing you pull the top of the bottom bezel towards you with two hands. It will come away from the screen face,keep on pulling until you hear the fasteners clicking out. Work your way round the bezel from left up to right down finishing at the menu switches. Its now best to lay the monitor face down and lift the back off as the switches are held in the front bezel and you will break the wires if you just pull the front off. Photograph it so you know how to reassemble. Reassembly is reverse, lay monitor on face locate back correctly and push down round edges to click in.
Feb 08, 2014 | LG FLATRON W2361V 23 inch LCD Monitor
How do you get the monitor apart?
First you take the little rubber covers off of the front of the monitor--I use a dentist's pick. Under the covers there are screws. Unscrew them.
Now VERY CAREFULLY pry the two halves of the bezel apart. They snap together and I find most times the top of the bezel must be pushed inward as you pry the halves apart.
Oct 11, 2010 | Acer AL2017 20" LCD Monitor
I have a Samsung 204B cannot remove rear cover
Don't use a sharp knife, it will slip and may cut you very badly. We use a small craftsman flat blade screwdriver with a tip about 1/8 inch wide. Start at the bottom but away from the control panel in the center of the unit. The front cover fits over the back part so when you insert the screwdriver tip go from the back to the front. You will have to press down and slide the tip from the back towards the front of the unit. The case should separate a little bit. Once the tip gets between the 2 halves then apply a bit of pressure by lifting the screwdriver. The plastic catch closest to the tip should pop apart and the case should open just a bit. Hold the front case apart from the back and move the tip down the edge just a bit and pry up again and just work your way around the edges. After the first one or two the rest will release easier. after the case comes off check our site to see how to get to the electronics boards at www.ccl-la.com
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 11, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Replace LCD screen
No, Remove the Screws On the Front Bezel Of the Screen.. (there should be 4 One on each corner), Then you will need a thin plastic tool such as a guitar pick or thin credit card... Pry the front plastic bezel from the back cover starting at the top right corner.. THe Whole Front Bezel Is Held On By Snap Down Plastic Tabs... You Will Need To Slide The Plastic Tool Along The Entire Top Of The Screen At an Angle... Then Once the top is insnapped, Do the sides, Then The Bottom.. Front Bezel Is Now Off And You Should Have Full Access To The Display...
You will have to Unscrew the screen from the Hinges On THe Left And Right Sides... Usually 2 or 4 screws on each side then screen is removable
Nov 17, 2009 | Acer Computers & Internet
2000 dodge intrepid driver door latch broken. When we take the door apart, there is a plastic piece that broke that attaches the handle to the rod that pulls the latch. It does not look like there is an...
We purchased a door latch to replace ours from Dodge. It came with instructions as follows:
Instruction Sheet
Front Door Handle/Bezel Replacement for LH
1. Remove the front door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
2. Place door trim panel on a clean work surface. Drill the mounting bosses' heat stakes, which attach the existing door handle/bezel to the panel, with a 21/64-drill bit. Take extra care to only drill in the center of each heat stake.
3. Remove existing handle/bezel from trim panel.
4. Clean the back of the trim panel of plastic fillings.
5. Seat the new handle/bezel into location.
6. Place the push nuts onto the handle/bezel bosses.
7. Use a 10 mm socket to install the push nuts all the way down on the mounting bosses to secure the handle/bezel onto the door trim panel. Using a wiggling side-to-side motion may be helpful.
8. Install the lock switch from the original handle/bezel to the new door handle/bezel.
9. Reinstall the door trim panel using the procedures outlined in Section 23 of the appropriate service manual.
Hope this helps.
Jul 02, 2009 | 2000 Dodge Intrepid
How to take Garmin GPS apart?
The front bezel, the silver grey plastic piece with the Garmin name on it will lift off.  Use a fingernail or a very thin tool to pry and lift it up.  Behind that are 4 phillips head screws.  Remove those and it comes right apart.  Look at the board on the top before taking it all apart to see exactly how it goes back in, it's a tight fight and has to fit just right.
Jun 20, 2008 | Garmin StreetPilot c340 GPS Receiver
Do you know how the cannon irc2620n comes apart ?
firstly, you may need four people, it's a heavy beast. But, you can remove the document feeder, all the cassette trays, the drum units which just pull out, the fineshir if there is one, the paper deck mto the right, the fixing assembly/duplex unit (two clips), Now try again with all this out and if need be - get two stronger guys.
I think you may need the service manual for disassembly procedures:
irc3200 manual is the same - download here
Jun 18, 2007 | Cannon Canon i960 Photo Printer
Is there an easy way to open this monitor?
-Flip the LCD face down and remove the screws that hold the base in place. -looking at the top edge of the LCD monitor you should see a small notch on each end between the front bezel and the back cover. -Using a plastic tool or a flat blade screw driver insert the tip and gently pop the case open. -Work your way around the edge of the case. -Once the LCD monitor is open unplug the control panel connector from the right side and remove the front bezel. Let us know if you have any other questions and please don?t forget to rate this post.
Dec 28, 2006 | Dell E173FP 17" LCD Monitor
Mitsubishi VS-55707 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
