Question about Epson Stylus CX9475 All-In-One InkJet Printer
It just says invalid operation please turn off. but nothing happens and it goes right back to error when I turn back on. There is no error code and all the lights are blinking at the time.
The printer says invalid operation please turn off and restart but nothing happens. it goes right back to the invalid operation error, but no error code to go by.
  • Sherlyn Cano
    Sherlyn Cano May 11, 2010
    What are you trying to do? are you trying to fax?
NJFIRESTORM
  • 84 Answers
SOURCE: Printer is on but cannot print
if your power light is off and the paper and ink lights are flashing try this.
1. remove all the paper,
2. open the cover and check for paper jam
3. make sure the ink cartridge lid is securley in place by opening and re closing the ink cartridge lid
reclose the lid, disconnect the power supply and hold the power button for 30 seconds. reinstall the power plug and turn the printer back on.
hope this helps
Posted on May 12, 2008
gwbm
  • 353 Answers
SOURCE: printer showing error
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. This is quite straightforward once you know what to do.
If you decide to have a go at replacing the ink pads yourself, post a new comment, and I will provide further help.
Posted on Feb 27, 2009
SOURCE: Epson Stylus dx8400 error message "a printer error has occurred"
I had this problem, turned out to be paper wedged too firmly in the intake tray. If you have this problem check for any obvious blockages such as the one I described.
Posted on Apr 12, 2010
willem52
  • 359 Answers
SOURCE: when i turn on the printer all the lights are
The Epson Stylus Color 880 has 4 LEDs. If all 4 are flashing or blinking then the printer has a maintenance request error. It means that the waste ink counter has reach its limit. The remedy is to replace the waste ink pads and reset the waste ink counter. You can use the SSC service utility to reset the protection counter. You can download the utility from here http://inkjetprinterhelp.us/epsonSSC.html
You can also use the control paler to reset the counter. Timing is the key to success when you reset the counter using the control panel so keep that in mind. To reset the protection counter using the control panel (front panel):
Step 1.Turn the power on while holdint the following buttons doen. Paper feed, cleaning button. (thr paper out light will flash for 3 seconds)
Step 2.While the paper out light is still flashing press the cleaning button for 10 seconds. The following leds will flash in sequence Ink out lights black and color, Paper out light. Once the printer starts to initilize the counter should be reset. This will reset the protection counter.
Posted on May 09, 2011
  • 6 Answers
SOURCE: two red light are blinking and show general error
unplug the printer and plug bag in. power up the printer. restart your computer, then try to print again.
if the printer won't power on at all. try clicking all the buttons on the printer, including the red blinking ones. one at a time. if this desn't work, turn off computer, search for the computer's driver software online and download it and reinstall it on your computer, following ALL directions. keep printer plugged in to your computer while your doing this
Posted on Mar 13, 2012
Frigidaire oven fpcf3091lf code eo90 comes on and beeps goes away but comes back.happened after power was out for a while
Frigidaire FPCF3091LF Complete Owner Guide English Page 30
click on the link above and check on page 30 on Setting Oven Controls
https://www.manualowl.com/m/Frigidaire/FPCF3091LF/Manual/173714?page=30
To restore all user settings to factory default:
step
1. press and hold 7 until first beep sounds
2. press start
May 30, 2015 | Frigidaire Ovens
I get this error on the printer screen 'A printer error has occured. Turn off the printer, then press On button to turn on. See your documentation.' However turning off & on doesn't work....
1 click the wreck symbol navigate your right arrow and look for factory or default settings
In case nothing happens ]
2; Turn off the printer .Move the cartridge carrier manually with your hands move it from left to right 5x
remove the cartridges all of them
3. clean the cartridges specially the gold and the area where the ink goes out with a clean paper or a dry cloth make sure its clean
- clean also the area where you put in the cartridges
try to turn on the printer make sure to close it properly before you tpo turn it on
May 23, 2011 | Office Equipment & Supplies
Well I am still looking for a answer to why the invalid key code has become invalid. What I would like to know how to get the key code to valid so I can reinstall Roxio easy Media Creator suite 9 back in...
invalid codes are not common but they do exist you will need to contact roxio inc at www.roxio.com tell them the problem supply the error install id number and they said they would be happy to supply you with a new code
merry christmas
please take the time to rank this advice below
Dec 25, 2010 | Computers & Internet
Started it but forgot that I did not turn the water on after a vacation. Got an error that said FH error. (water inlet error) I tried hitting the PAUSE/SELECT twice - nothing. It still says "locked" and...
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display and then check:
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 25, 2010 | Washing Machines
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Jul 15, 2008 | Ricoh Aficio 2015 Copier
RCA OPAL M4008 MP3
Mine has the same problem too, it says boot error, I format the unit, nothing happens. Dang!
May 29, 2008 | RCA OPAL M4001 MP3 Player
Lexmark X73 just stopped working totally
I was printing a homework assignment from my professor, I received an error message that something may be invalid with what he sent. I tried to print and everthing just jammed, the cartridges are stuck to the right and noting will move. I have turned it on and off and even unplugged it from the Computer, but when restarted nothing still happens there is still no communication with my omputer. Is it shot or can still use it? Thanks Rebbec
Apr 14, 2008 | Lexmark X73 All-In-One InkJet Printer
Error codes on kitchen aid range
Hi.
F2 E1 is a keypad connection error.
Here the complete list of Kitchenaid error codes:
Troubleshooting KitchenAid oven, range and...
Feb 11, 2008 | Kitchen Ranges
Epson Stylus CX9475 All-In-One InkJet Printer Logo
159 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
