Question about Sony BRAVIA Televison & Video
How do I get the HDMI1 header bar off screen
The HDMI1 dolby digital 2.0ch 48kHz 448Kbps is in a shawdowed header bar
    New Friend:
    Problem Solver:
  • 7 Answers
Can you help me to log in my acount
Posted on Jan 01, 2014
Optical Audio Output Formats for PS3
look in your receivers manual or download it using a google search
Dec 23, 2013 | Kenwood VR-606 Receiver
I just bought the JVC Everio GZ-MG330 and when I playback the video there is barely any sound even when I set the volume to the highest possible number. Does this mean the camara is no working properly.
Try resetting the unit:
To reset the camera
1) Close the LCD monitor to turn off the
camera and remove the power supply
(battery pack or AC adapter) from the
camera, then reattach it.
2) Select [FACTORY PRESET] from the
MENU.
If still no sound replace it...
Hope that helps........
Jul 19, 2008 | JVC Cameras
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
Wil not switch to dolby digital mode
You must use optical sound wire in order to reprduce dolby digital......You should have 2inputs on the back for this......plus the signal must be broadcasted in dolby digital.Such as HBO,SHOWTIME....they will tell you before the show comes on whether or not the movie or event is being broadcasted in dolby digital.Your unit will automatically change to dolbly digital once the show or event starts.Just make sure your input on video1,2,or3 is set to optical1 or 2.Just press the "Audio Sel" on the remote to change the audio source.But make sure the optical wire is connected first.....And just incase,make sure you are sending a dolby digital source to the unit from the sat reciever,cable box,playstation2.....make sure the dolby digital/optical option is on.You can find out what audio options you have in the menu screen.........or the redneck way.look on the back of the sat reciever/cablebox/playstaion2 ect...for a red laser light comming from these units.........i hope tht helps.
Feb 20, 2009 | Onkyo HTR500 Receiver
How to hook up a boston acoustic ba7500g speaker
you can connect the BA7500G speakers to a regular digital coaxial output by using a cable that has an RCA plug on one end and a stereo minijack on the other. However, the pole of the RCA must connect to the tip of the stereo minijack and the shield of the RCA must connect to the middle ring on the stereo minijack. Also set your soundcard to output at 16bit and 48khz.
Oct 19, 2008 | Acoustic Audio Players & Recorders
LCD is dark, can only see shawdows
press and hold the Fn key down
while holding it down press the up arrow key to increase the brightness.
key combination
Fn + up arrow key
Jun 12, 2008 | Dell Inspiron 1200 Notebook
Bad sound through HDMI
Is it only in Games or Movies?
Try checking the cables. (obvious I know but it must be said).
On the XMB (Cross Media Bar), go to settings on the left. Scroll down to "Sound Settings"
Choose "Audio Output Settings", then "HDMI", then "Auto"
If that doesn't fix it then choose manual and the most basic outputs first;
-Linear PCM 2ch. 44.1KHz
and
-Linear PCM 2ch. 48KHz
Depending on your surround sound setup your could get away with other options as well. Fist determine if your setup is 5.1 or 7.1, DTS or Dolby Digital. Then start with the lower KHz settings and work your way up.
Dec 12, 2007 | Sony Playstation 3 (PS3) Console
Hook up your Xbox to a Dolby Digital Decoder
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
